Not low enough stance - Page 2
Old March 31st, 2011, 05:04 PM   #21
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
The reason it says not for verts is because verts are heavier by a few hundred pounds
Build Thread
Old March 31st, 2011, 07:29 PM   #22
Dancing Naked In The Rain
mcqueen's Avatar
Originally Posted by boblongtv View Post
I have had them on for about 8 months. Since i have 40 wide tires idk if she will rub on the fronts. what u think?
Your tires are actually 245 wide. The 40 in the tire size refers to the sidewall. It means the sidewall is 40% the size of the tire width. That 40 translates into 98mm on your tires. With a good set of shocks and struts I don't think you'll have too worry much about rubbing.
My Hubpages
Hey.. r u really a tranny??
Old March 31st, 2011, 07:30 PM   #23
you beat me to it...
OP please post a pic of your stance...honestly a slight cutting will fix any height issues you have
Old March 31st, 2011, 11:33 PM   #24
BlueScreaM's Avatar
Better than ONLYaUNCfan's
2012@lightspeed
BlueScreaM has a spectacular aura aboutBlueScreaM has a spectacular aura about
Originally Posted by 01SilverSixer View Post
When buying springs you have to think about that springs made for a v8 aren't going to lower a v6 as much because it's lighter.
I have v8 lowering springs.
OP remove the isolators then see how you like it.
Before
After
Formerly, AhobosCheese and Cheddars.
Old March 31st, 2011, 11:38 PM   #25
BlueScreaM's Avatar
2012@lightspeed
Closer shot.
Threads Similar to: Not low enough stance
Show Us Your Stance .... serbiandude Pictures 735 April 24th, 2012 09:07 PM
better stance 1fasts/c2003 96-98 11 February 26th, 2011 10:40 PM
Need help with the stance of my car... tater302 99-04 17 February 5th, 2011 05:49 PM
New stance on my GT w/ IRS. 99mustanggtman Pictures 23 March 25th, 2009 01:31 PM
mean stance ponygt 99-04 9 June 25th, 2008 10:13 PM
