1998 Mustang V6
1998 v6 swap
I was wondering, i just got a 1998 mustang v6 5 speed, what would i have to do to swap in a 1999-2010 v6 and how much might it cost, if its possible. I dont need tips on swapping in a v8 because insurance is too high.
thanks |
'00 V6 Procharged Mustang
Insurance wouldn't be any higher if you swapped a V8 in. It'll still be registered as a V6.
You'd only be able to swap a 99-04 in as far as I know. Why would you even want to though? -Is there something wrong with your current engine? You can quite easily convert it to split port and then it's essentially the same as a 99-04.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
14.37 @ 96
go to the search button, click advanced search, type in engine swap, select V6 section only, read.
Ive been reading about engine swaps for the last 2 hours .... |
14.37 @ 96
Welcome to MM btw.
2000 mustang v6
14.6@99.68
Do what I did.....buy a 99-04 v6...I got my first stang (97) realize the 99-04 were more b.a cuz there split port...and saved saved saved saved......and saved lol
Win
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust Fixed clutch!!!!! "My mustang likes a good ol' fashion bowl of rice....especially fried" |
[8MINUS2]
jw, whats up with your time you have posted
2000 mustang v6
14.6@99.68
B.s time just messn round my goal idk if the mph is correct but the time...I wanna break 14's but idk
1998 Mustang V6
nothings wrong with the engine i just wanted more power, how would i covert it to a split port?
Search around. There are hundreds of threads on it.
Modded V6
heres the parts list to do a split port swap:
-97+ f-150 V6 heads or 99+ mustang v6 heads (including valves/springs) -97+ f-150 v6 lower intake, or 99+ v6 mustang lower intake * -99+ mustang v6 upper intake ** -99+ mustang EGR tube and valve (f-150 tube will work) -99+ Throttle Body -TPS sensor for TB (1-CX-1488 from Ford) if not already on TB -Throttle cable from 99+ mustang v6 -Modified fuel rail that has a universal fuel pressure regulator, and a return line. (available from SteveC) *** -Accelerator Bracket (F4SZ-9728-B) if not already included on upper intake -99+ mustang v6 coil pack and wires (your stock coil pack will work too) -99+ mustang intake tube, or any 99+ mustang CAI kit -99+ mustang cooling hoses (including the ones going to the heater core) and pipes. You can also make your own lines, by using plumbing elbows,hoses and clamps, and fab it up yourself. (Definately get these if you can.) -16 a.w.g automotive electrical wire -teflon tape, pipe sealant, RTV -99+ head bolts/studs -head gaskets (I recommend 99+ mustang gaskets) -99+ upper and lower intake manifold gaskets. -99+TB gasket -94-98 IAC gasket -94-98 valve cover gaskets(reuse the 94-98 valve covers, valve cover gaskets can be reused if removed carefully) -94-98 exhaust header/manifold gaskets -you can reuse the 94-98 headers **** -use the 94-98 IAC since the 99+ IAC has a different connector (Edit: I found that the IAC I used from a 99 mustang had the SAME connector. I am not sure about other years or F150's/windstarts, but the 99 IAC will work and I recommend using it for a cleaner looking install.) -rad fluid, oil, filter, new spark plugs -gasket remover, thinner to prep parts before applying new gaskets
![]() 1999 e46 328i BMW - Daily Driver 2001 SVT Cobra - Project 1995 v6 vert - SOLD 1996 v6 vert - SOLD 1995 v6 vert #2 - SOLD 1995 GT - SOLD 1997 v6 coupe - Parting |
2000 mustang v6
14.6@99.68
You can do tht
Or Buy a pulled engine and "drop" it in there....kinda Or like I said buy a 99-04 v6 or if u rly think about it get a gt lolololool ![]() I'm not being a smart ass or sarcastic its me just saying
muneris pro ego
You could buy my m90 kit, add a few more parts, and have approx 210hp and 310tq.
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
2000 mustang v6
14.6@99.68
The best part is....310 tq...I say tht because usually when ppl talk numbers the hp and tq r kinda close...not this time....why is tht...? Is tht the s/c?
muneris pro ego
its because of the type of supercharger. if you look at the stock power/tq, a 96-98 sixxer has 150/210, the roots supercharger adds more tq than hp
2000 mustang v6
14.6@99.68
......and tq wins races good sir
Lol
Threads Similar to: 1998 v6 swap
| Cam Swap On SOHC 4.6 1998 GT | Casper98GT | 96-98 | 134 | February 25th, 2011 08:19 AM |
| 1998 v6 wanting to swap for a 4.6l | jrp11888 | V6 Mustangs | 10 | June 14th, 2010 05:05 AM |
| 1998 auto v6 351 swap | a1cmagodd | V6 Mustangs | 0 | September 15th, 2009 02:34 PM |
| I want to swap a 5.0 into my 1998 gt | Fast98stang | Modular Mustangs | 6 | April 17th, 2008 08:40 AM |
