#21 |
01 GT
Where in Florida do you live ? I would stop guessing and take it to a ASE certified tech. That's just me. It doesn't sound like the camshaft pos. sensor.
![]() [ d I [] fa I [] nt ] |
#22 |
I live in pasco county about 25-30 mins from Clearwater. I would take it to a shop but I def don't have the money for that unforunately so I'm on my own with this one ugh..
#23 |
Here are a couple of tips to locate where the noise comes from. Get an empty paper towel tube and put it close to your ear, and move it to different parts of your engine. This should help you find sounds that are made outside of the engine, pulleys, alternator, EGR, power steering, etc.
Take a large screw driver and put it in your ear and put the blade on different parts of the engine. This will tell you where the sound originates inside the block. You can hear a spun bearing, rod knock, noisy lifters, etc. Hopefully the noise is not inside the engine! |
#24 |
Alright so I took it to the shop and they looked at it for free and said it was the cam synchro. So now I have to spend 200 bucks on the part to replace this but Im gonna do it myself cuz I dont have the money to buy the part let alone the mechanic to install it also. What do I need to know about replacing this part? Any input, suggestions, instructions etc would be of great help. Thank you!
#25 |
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
I have that laying around I think. What all do you need? Maybe it just needs to be adjusted
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
#26 |
I believe I need the alignment tool and the whole cam synchronizer. From what Im reading some people are saying I have to align the engine at TDC to do this job so I may need a compression gauge to this job as well but others are saying as long as you keep the alignment right when you switch the synchro out you should be fine.. any input on that as well?
#27 |
1 Wheel Peel
2000 Mustang 393w
Pull out your cylinder number 1 spark plug and see when the piston is tdc... Or look at the markings on the crank pulley
#28 |
So in theory.. wouldnt I be able to just take the old syncro out and put the new one in without having to worry about lining everything up at TDC as long as the new one is in the EXACT same spot as the old one?
#29 |
2003 mustang v6
Its your camshaft synchronizer!
Threads Similar to: Help!.. Major Screeching/Squealing Under Hood... **VIDEO INCLUDED**
| Excessive Screeching/squeaking from under hood | lwhitetrash88l | V6 Mustangs | 10 | February 11th, 2011 08:55 PM |
| weird sound video link included | Demelle | 99-04 | 10 | December 17th, 2010 11:13 AM |
| video of me trying to drift, link included this time | stangman92 | 99-04 | 8 | June 28th, 2010 06:32 AM |
| weird squealing/screeching noise | RedDevilGT | V6 Mustangs | 28 | March 12th, 2009 06:00 AM |
| Squealing noise under hood | hardhitter | 99-04 | 29 | August 29th, 2008 11:37 PM |
