Swapping '99 v6 engine with '02 v6 engine
Does anyone know of any problems I will have replacing my '99 v6 engine with an '02 v6 engine?
I just bought it at a junkyard to replace my original engine with a blown head gasket. It appears that the coil pack is smaller. |
Why didn't you just replace the head gasket? Did it fubar the engine?
#3 | |
![]() New block with forged internals running 16psi, tuned by Lasota Racing Too many mods to list... 3.73's and Truetrac Finally Done!
¡ʇsnq ɹo uʍop ǝpısdn
nope everything should transfere right over... i think... wanna sell me your old motor... ill come pick it up and maybe buy you lunch in exchange for it
you will need to transfer over a few sensors the master harnes the ecu and the cluster because the PCM will be looking for a digital cluster as well as some of the sensors are made for the PCM that is on the digi cluster. otherwise good to go it will bolt right up to the tranny bell housing and the motor mounts.
engien
only diffrence is the intkae manifold is split port on that year, not worth swapping
2003 Mach 1, 5 speed ![]() U.S. Army - 11B "And on the 8th day god created the infantry and all hell stood at attention" |
#7 | |
Re: Swapping '99 v6 engine with '02 v6 engine
I don't drive fast. I fly slow.
02-04 lower intakes have IMRC (Intake Manifold Runner Control) valves. 02-04 PCMs also have specific parameters for this system including actuation and spark (timing). Replace the 02's lower with your 99 lower.
2002 Summer Beater |
#9 | |
and he will have that whole whopping extra 3 hp lol and also IMRC don't it improve low end torque marginally so i say keep it and grab the 02 PCM
#10 | ||
#11 | |||
2000si: I am new to engine work. See my post
http://www.moddedmustangs.com/forums...n-vt22644.html Onemanzu: I plan on doing a slow rebuild on my '99 engine...maybe mod it a bit. I don't usually turn down free food, but I will have to this time. If I give up on the '99, I'll post and sell it later. Thanks for the info guys!! Mustang RacR94: Why is the split port worse than what I have? IYO Let me say this, I bought a complete 02 engine at a junkyard (except bolt-ons...altern,compres,etc) I plan on taking what the 02 engine doesn't have off of my 99 engine and then drop the completed 02 right in. Option 1: Replace the 02 lower intakes with my 99s Option 2: Use an 02 PCM to control the power. First, where is the PCM located? Is it attached to the engine or the firewall or what? I probably don't have an 02 PCM if it isn't attached directly to the engine. I really appreciate the feedback here...I plan on swapping the V6s this weekend and it sounds harder to do than I first thought. |
#13 | |
Hm, I wonder how the PATs will work??? I can't remember how the coder is read. Also, check to see if the PCM still varifies the odometer modual. I can't remember if they each store syncronized readings as a form of an odometer freud deterant.
#15 | |
My apologies if some of this has already been said.
1. Mustang RacR94: Why is the split port worse than what I have? IYO The 99 and 02 both are split port intake. So the 99 intake manifold should fit on the 02. This was corrected above. 2. Option 1: Replace the 02 lower intakes with my 99s I would strongly recommend this route. Use the 02 long block as is and swap on the 99 intake manifolds and associated parts. I believe the long blocks should be the same. This would avoid potential problems with incompatability with the 99 ECM. 3. You might want to use the 02 valve covers. The 99 has a problem with sucking up too much oil through the PVC which carbons up cylinders 3 and 6 and causes preignition problems. |
#17 | |
That may depend some on what state he is in. I don't know what TN requires, but in CA one could get into a lot of trouble installing a non original engine when it comes to emissions requirements.
Recently there was someone on here who had swapped in a later engine and couldn't get a smog certificate. |
#19 | |
#20 | |
Zoolander
04 Cobra #2260/3768 1/820
Re: engien
Threads Similar to: Swapping '99 v6 engine with '02 v6 engine
| Engine Swapping | OcOnnor220 | 99-04 | 1 | August 16th, 2007 09:05 PM |
| engine swapping | IWantToGoFast | 5.0 Mustangs | 15 | June 11th, 2007 11:41 PM |
| Swapping engine! | DanishStallion | Modular Mustangs | 1 | April 6th, 2007 12:12 AM |
| Engine swapping question | Wesf90 | 99-04 | 5 | April 3rd, 2007 10:35 PM |
| Engine Swapping | pun-stang-man | 5.0 Mustangs | 6 | March 3rd, 2007 03:11 AM |
