85 Gt, 95 Gt
98 v6 fuel pump or other issues. Help
I am helping my buddy get his sixer going and we run into a little
snag with fuel issues. Here is the problem... The pump will prime the system for 1-2 seconds after you turn the key to the on position but when you crank it the pump does not run. Any suggestions? Oh yea, Just replaced fuel pump today. Kinda leaning towards cam sensor but everybody says most of the time it will just run like crap if bad.
Only a true car enthusiast can appreciate any car. |
1999 Mustang Pony
Not even currently moving
![]() iTrader: 2 reviews
Sounds more like a fuelpump relay to me... have you tested it yet... should be another one like it in the box in another spot pic one that wont inhibit the car from running and swap them out, if it works your problems solved, if not i'd start trouble shooting elsewhere.
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's |
85 Gt, 95 Gt
Well we tried just about everything.
Acording to the shity haynes manual there is only a fuel pump fuse. The fuel pump and injectors seem to be controlled by the little computer below the air filter housing. I cant remember the name of the computer, some kind of relay module.
85 Gt, 95 Gt
Ok I just looked at the manual its called the
Constant control relay module. The book says this module and the pcm work together to control the fuel system. But I have never heard of either of these two going out.
1999 Mustang Pony
After googling the ccrm i found another guy whohad similar problems, is the fuse popped? the other guys fuse kept popping and he had a melted wire touching an exhaust pipe, causing a short to ground which he originally believed to be a ccrm problem, just something worth looking for.
85 Gt, 95 Gt
No it doesnt pop the fuel pump fuse but untill we put
a new alternator in the car it kept blowing all of the fuses under the dash. The kicker is the fuel pump runs for a secont to prime the system but doesnt pump or fire the injector when you crank the engine. thanks for the research i have been looking around also on how to test all of the components before we start throwing parts at it. Also has anyone on here ever seen a crank sensor or a cam sensor cause this issue.
97 Mustang V6
Hmm sounds like u have the same problem i got with my other 6'er. i bought a new fuel pump just the little pump its self not the whole thing. it's 300 for the whole thing. when i saw it was changing it n shit the left rubber hose had a crack in it so i super glued the hole and changed the pump and my 6'er fired up like that was the problem but it wasnt. come to find out 1 of my fuel injectors is bad. not saying it's ur's but maybe its a fuel injector? it's a bitch to replace and their pricey lol. also i found out i have a crack on 1 of my cat's but i got no exhaust leak. hope u figure out the problem!
#8 | |
1999 Mustang Pony
#9 | |
2000 V6
85 Gt, 95 Gt
Quicksilver- We dont know about overcharging my buddy bought
this car not running so we dont know. It just popped fusses when you turned the key on. After we replaced the alternator and fixed a few bad wires all of the fusses do not pop and they make everything work they go to. Oasis- yes we did yake the cam sensor off and clean it and tested it. We went by the book and my only concern is that it would backbrobe with the key on 5 volts for a split second while slowly manualy turning the engine over. I figured it would hold 5 volts as long as the little cam syn was in line with the sensor, but i dont know we are still searching. Everybody we talk to says replace the ccrm relay and it will fix it. tommorow we are going to pull the ccrm and take the cover off of it and put voltage to it and manually check all of the relays before we buy a new one.Hope we find the problem. Thanks for the input anymore advise would greatly help.
Threads Similar to: 98 v6 fuel pump or other issues. Help
| fuel pump issues | ocejo | 2.3 Mustangs | 29 | January 13th, 2011 10:32 AM |
| Fuel pump issues | 98mustang | 4V / SVT | 1 | October 26th, 2010 09:36 AM |
| Fuel Pump Issues | ~C~ | Modular Mustangs | 8 | October 1st, 2008 07:19 AM |
| Fuel Pump Issues | acehogg69 | 2005 - 2010 | 14 | April 11th, 2008 11:38 PM |
| fuel pump issues | lynn | General Tech | 0 | August 30th, 2006 04:07 PM |
