Forged internals
Old May 3rd, 2007, 06:45 PM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
Forged internals
Are they only needed for going FI or would I need them at a certain n/a power level
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old May 3rd, 2007, 06:48 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
you only need them when running high boost from a turbo, supercharger and sometimes nitrous
Old May 3rd, 2007, 06:58 PM   #3
2000 V6
Ah ok...thanks...btw internals wouldnt add hp right
2000 V6 vert
Old May 3rd, 2007, 08:20 PM   #4
02ponypackage's Avatar
02ponypackage is on a distinguished road
yeah
just a V6 with a bad belt slip under the hood
Old May 3rd, 2007, 08:22 PM   #5
Mod of the Year '11
2021 Mustang V12
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
Originally Posted by 02ponypackage
yeah
"yeah" as in they would? or "yeah" as in they wouldn't?
Cars and mod list in garage
I prefer a girl with a cafina
That's Spanish for vaheena
Which is Italian for clam
Old May 3rd, 2007, 09:10 PM   #6
2000Si is on a distinguished road
Depends. If you build the engine to a higher compression ratio then internals are part of that equation and you could gain horses from it.
Old May 3rd, 2007, 09:13 PM   #7
TurboLX's Avatar
it all depends on how you build it, theres different types that can and cant add hp
Old May 3rd, 2007, 09:21 PM   #8
02 Mustang V6
13.605 @ 101.60
Garman91 is on a distinguished road
iTrader: 6 reviews
Basically if you replace your stock parts w/ identical forged internals - No HP gains
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
Old May 3rd, 2007, 09:26 PM   #9
they "will" help
Old May 3rd, 2007, 09:27 PM   #10
well if u get performance forged made for power...at least...if u can have a stock part forged no
Old May 3rd, 2007, 09:36 PM   #11
If you replace your internals with stock specs (which isn't likely to happen) then your power increase will be negligable.
But since you have to bore/hone out cylinder walls while replacing pistons/rods, you might as well increase your stroke while you're increasing your bore. That'll yield some gain. Not massive amounts, but maybe 2-5 hp depending on how much you increase the stroke length and bore out the cylinder walls.
Threads Similar to: Forged internals
Forged Internals leebunnyz 2005 - 2010 15 August 9th, 2007 11:26 AM
Forged internals? energiesource 99-04 27 May 14th, 2007 02:50 PM
Going to forged internals...what to get? ltsmash1200 99-04 7 April 23rd, 2007 12:08 AM
forged internals FastBack71 5.0 Mustangs 6 January 17th, 2007 08:58 PM
Forged Internals Rolis V6 Mustangs 7 December 5th, 2006 12:15 AM
