2003 V6 Mustang
The Infernal Squeak! Make It Stop!
In the last two weeks i cut my stock springs. 1.5 coils in front, .75 in back. Isos in. I absolutely love the stance and the handling, however, there is a problem. As i drive, the front drivers side begins to squeak, a little bit and fairly quietly for the first few minutes and then progressively worse until it drives me crazy to have the windows open cause of the stupid squeaking. I feel it makes my car sound junky and I can't stand it. I've tried to figure out whats causing it and i've made sure to tighten everything down so nothings loose, but to no avail, the damn squeak persists. I'm thinking maybe the iso but idk how the iso could be that worn on a car with only 55k miles. Any suggestions on what to look into?
Also, it didn't seem to squeak as much when I drove her in the rain.
Dancing Naked In The Rain
Did you remove the isolators? If so, it's the springs rubbing on the metal. Some grease would probably help. I've heard wrapping the ends of the springs with duct tape or electrical tape helps, but I imagine the springs would wear through them pretty quickly.
#3 | |
Needs 2 cylinder bolt on
'03 Mustang V6
It's a six so what do you expect?
1999 mustang cobra
![]() iTrader: 1 reviews
Yeah try to make sure they are positioned correctly on the control arm
Black and White Crew Crew Member # 5 Check garage for mods and pics if you Los Angeles and want to ride send me a text (323) 270-6827 0% Wheel hop, 0% broken parts, 100% wheel spin |
Threads Similar to: The Infernal Squeak! Make It Stop!
| O M G....Make it stop!!!!!! | tinkerbell_too | The Clubhouse | 69 | April 11th, 2011 01:49 PM |
| Make It Stop | mcqueen | The Clubhouse | 39 | January 17th, 2011 10:09 PM |
| Make It Stop! | mustang003 | The Clubhouse | 30 | June 22nd, 2010 08:02 PM |
| Isolators: Squeak or no squeak? That is the question. | freefallin2000 | 99-04 | 22 | April 12th, 2010 11:47 PM |
| Why did ford make speedometer stop at 140!? | FLA Dreadhead | 2005 - 2010 | 10 | March 15th, 2007 06:12 AM |
