No turn signal
Old May 5th, 2007, 01:52 AM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
No turn signal
OK I have both front and rear left signals and only the rear right signal. The bulb would light up but not flash so I replaced it, still didnt blink, I also checked the fuse which was good and nothing. What am I missing here?
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old May 5th, 2007, 01:54 AM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
this happened to my fox bod, its caused by another signal or light thats running hotter so its not supplying the power to make it blink, i just replaced all the bulbs
Old May 5th, 2007, 01:59 AM   #3
2000 V6
Well it was happening with the stock bulbs at first...now I have silverstars and new corner lighs too...so replacing the bulbs is out i think
2000 V6 vert
Old May 5th, 2007, 12:42 PM   #4
TurboLX's Avatar
well eiher way its a hot wire thats causing it somewere
Old May 6th, 2007, 07:49 PM   #5
2000 V6
Any idea where to look...
2000 V6 vert
Old May 6th, 2007, 09:10 PM   #6
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
dont replace all your bulbs.
some where and some how the wiring is misconnected or bad
[SIGPIC][/SIGPIC]
Acmillr loves me
Old May 6th, 2007, 09:28 PM   #7
2000 V6
weel bulbs are already done...where should I start looking for bad wiring
2000 V6 vert
Old May 6th, 2007, 09:32 PM   #8
00 V6 & 09 GT
idk, it actually might be the socket, but it wouldnt light up...never mind, to lazy to backspace.
its gotta be a wiring or fuse.
i can ask somone at my work tomorrow that knows a lot about lighting
[SIGPIC][/SIGPIC]
Acmillr loves me
Old May 6th, 2007, 09:33 PM   #9
2000 V6
THe fuse ws good too...
2000 V6 vert
Old May 6th, 2007, 10:35 PM   #10
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
this is nuts because this happened to me once but not in my mustang. I had the tail light illuminate but NOT blink. I figured it was the bulb so I went and bought a new one and the same thing happened again.
This is what was so stupid. The bulb I bought was bad too! Apparently there are TWO filiments in the bulb. By stupid ass chance, the new bulb had one of the filiments blown.
The third bulb did the trick becuase I checked it before I left autozone.
I dont know if mustangs use that kind of bulb but it might be worth checking just to eliminate the possibility...
Old May 6th, 2007, 11:14 PM   #11
Mustang RacR94's Avatar
03 mach 1
13.2@109
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
turn signal
could just be the flasher, it cost like 6 bucks at autozone, and is located by your pedals unerneath by all that jazz, is a roundish, thing and is usally silver, turn signal wires hardly go bad that quick
2003 Mach 1, 5 speed
U.S. Army - 11B
"And on the 8th day god created the infantry and all hell stood at attention"
Old May 7th, 2007, 12:09 AM   #12
2000 V6
I did check the bulb both filliments are good...both the old bulbs were too...Is the flasher in there with the rest of the panels or is it seperate
2000 V6 vert
Old May 7th, 2007, 11:03 AM   #13
03 mach 1
13.2@109
flasher
I dont beleive its with the rest of the fuses, its around that area thu, at least it was in all my other cars
U.S. Army - 11B
Old May 7th, 2007, 11:10 AM   #14
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
bad flasher i had a tempo that did this. replace the flasher module.
Old May 7th, 2007, 12:39 PM   #15
Midnight Stang02's Avatar
2002 Mustang v6
Midnight Stang02 is on a distinguished road
Send a message via AIM to Midnight Stang02
just to save a headache might as well just change all the bulbs
not that expensive
Old May 7th, 2007, 03:39 PM   #16
2000 V6
Ill check the flasher...how do I tell if its bad
2000 V6 vert
Old May 7th, 2007, 03:42 PM   #17
Juggalo_X's Avatar
14+@Slow
when you turn your signal on look in the fuse panel, you should hear click click click thats the flasher relay cycling if you dont hear it then the flasher is bad or you have a hot wire. this is usually caused by a burn out bulb. but you say both bulbs illuminate but dont flash so im betting the flasher is the culprit.
Old May 7th, 2007, 03:44 PM   #18
2000 V6
Yeah ia lights up but the front right doesnt flash, the rest do
2000 V6 vert
Old May 7th, 2007, 03:46 PM   #19
Juggalo_X's Avatar
14+@Slow
pull the harness off and look for a burn connection, if not the flasher module is probably bad.
Old May 7th, 2007, 03:52 PM   #20
Juggalo_X's Avatar
14+@Slow
Turn on your Emergency flashers if all 4 flash your Primary signal flasher is shot replace it.
Threads Similar to: No turn signal
Turn Signal MnrlGry01gt 99-04 13 October 16th, 2010 06:18 PM
Turn signal help novamastr 5.0 Mustangs 16 January 26th, 2009 03:52 PM
Turn Signal Youngin The Clubhouse 11 August 18th, 2007 10:20 PM
turn signal? thatonekidw/theGT Modular Mustangs 3 July 22nd, 2007 06:39 PM
Turn Signal CBSTANG 99-04 9 May 28th, 2007 12:38 PM
