1999 Ford Mustang GT
A Couple Questions
First off, while changing my oil i noticed that my exhaust (which was installed by previous owner) is running a y-pipe cat-back flowmaster system, it seems to have a dent on the "Y" that comes off of the mid-pipe and into the muffler on the passenger side. It seems to be bent/dented/crimped on purpose to pass beneath the driveshaft. I'm wondering if anyone else has had this problem with their setup, and should i just get an h-pipe to bypass the driveshaft?
Which also leads me to whether i should get and h-pipe or a prochamber mid-pipe. What are the advantages and disadvantages of each? |
Sounds kinda wierd is it a Y with dual exits
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
MM's Resident Ricer
2006 Scion tC
13.001@113
pics please that sounds weird, and yes get true duals with a crossover or an h-pipe it will breathe better
im not trying to make fun of you but i wouldnt doubt if thats just where the exhaust bends and you think its bent. and where its bent it'll obviously be crimped on the inner part of the turn.
just take that junk out and get true duals
I will get pics up soon, but itschristorres8 it's deffinately not like that. it looks smashed down conveniently below the driveshaft. here's a diagram of where the dent is
![]() I am going to get true duels soon, but should i go with straight pipes, h-pipe, or prochamber |
then its more then likely you or the previous owner went over train tracks or speed bumps at one point fast and happen to ding that area or bend it.
the dent is on the top of the pipe facing the driveshaft though, not the ground
bends
if its just looks like like lines running parrell to each other on the inside of the the bend then thats normal, if not you hit something
2003 Mach 1, 5 speed ![]() U.S. Army - 11B "And on the 8th day god created the infantry and all hell stood at attention" |
MM's Resident Ricer
2006 Scion tC
13.001@113
do you hav an x-pipe like that?
Yeah is that how your exhaust is set up
yes, but it doesn't seem like an x-pipe, as the piping doesn't cross till the cat-back meets the old mid-pipe
MM's Resident Ricer
2006 Scion tC
13.001@113
ok so yours is one pipe that splits into two like 2 from cats then a semi long single pipe and then the catback?
sounds more like a "y to y" setup to me
especially cuz up until recently the only KIT flowmaster sold was y to y and in my experience previous owners tend to use kits when they do any kind of modification. |
#14 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
ok so it is a Y pipe kit. Get pics of the dent cause most y kits are made to bolt right up and a dent is not supposed to be there
Yeah how would a y pipe not fit right???
Ya there are plenty of ypipe duals out there, a ton of "dual" exhausts that are on stock cars stem from a Ypipe, hence not true duals. If the dent is on the wrong side then gg someone either A) installed it very poorly or B) they installed it very poorly and the driver bent it by getting some nice air. Either way you arent going to want to touch it until you get an hpipe and keep the mufflers you have now. Take it somewhere and they can put it all together, or have them just fab the straight pipes with a crossover (hpipe)
The George Forman of Keepers
is the dent restricting your airflow? Thats what i'd be worried about. Gas mileage , performance etc...
#19 | |
The gas mileage may be suffering, but since it's been like this since i've gotten the car 1 month ago it would be tough for me to know. Anyway I got some pics, tell me what you think
Threads Similar to: A Couple Questions
| Just A Couple Questions | Youngin | The Clubhouse | 44 | November 13th, 2007 03:11 AM |
| Couple Questions | Youngin | V6 Mustangs | 12 | October 8th, 2007 09:49 PM |
| couple questions | MisterFast3 | V6 Mustangs | 23 | September 18th, 2007 10:55 PM |
| i have a couple questions | rx1_ns | 96-98 | 25 | July 10th, 2007 06:25 PM |
| a couple questions | trueballerisme | 2005 - 2010 | 7 | December 10th, 2006 04:39 AM |
