DDM HID lights in...but confused..
Old May 13th, 2011, 07:52 PM   #1
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
Okay from the picture below I'm not sure what to do here....there were no instructions anywhere in the box. everything else plus into theyre appropriate plugs but then theres this little guy....
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old May 13th, 2011, 07:52 PM   #2
2001 Mustang 3.8l
Old May 13th, 2011, 09:32 PM   #3
1999 V6 Mustang
SALEEN961 will become famous soon enough
I ran into the same thing, they have the pinout on their site in the support section.
https://www.ddmtuning.com/support/in...loaditemid=151
Old May 13th, 2011, 10:36 PM   #4
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
If I remember correctly, it goes the way you have it in the picture.
The brown/black is the ground, which goes in the middle.
The white is lows, blue is highs.
I'm pretty sure mine went white, brown, blue.
If your highs are on without turning them on, switch the white and blue wires.
Build Thread
Old May 14th, 2011, 11:09 AM   #5
2001 Mustang 3.8l
going to do this today and mount ballasts, do you guys know if the brights are on when the HID bulb is pulled backwards? i noticed that when i hit the bright switch the HID bulb clicked and pulled itself closer to its connection.
Old May 14th, 2011, 11:52 AM   #6
SlowSix's Avatar
2001 V6
15.47@89.57
Just go inside your car and look at the dash. If you headlights say the brights are on in the regular headlight position you wired it wrong. And yeah the headlights suck in and out based on your highs or lows. Not sure which way is which though.
Build Thread
Old May 14th, 2011, 02:14 PM   #7
Wing on, wing off...
MRKsD3's Avatar
JULY 2011 ROTM
MRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of lightMRKsD3 is a glorious beacon of light
Look at the 9007 pigtails in our car... You should insert those wires into the socket so they when you put the socket into the pigtail, the colors would match accordingly... If I'm bit mistaken... One wire is positive, the other is neg, and the last one makes it shift to high beams...
SIG BY WABASHACOBRA99
Old May 14th, 2011, 03:00 PM   #8
2001 Mustang 3.8l
our stock wires are not the same colors, the wires on DDM's side are Blue Brown and white. White--->white green, brown--->black, and white--->.....the last wire, i forget the color...but they are in now and look beautiful. ill post a pic later in the "what have you done to your stang, the mounting spots are amazing.
Old May 14th, 2011, 03:22 PM   #9
MRKsD3's Avatar
JULY 2011 ROTM
This is my stock wiring on the driver's side...
This is my DDM wires...
Why not try white on white, black on brown, green on blue... If it isn't the correct order... Just switch the around...(white on blue, green on white)
Threads Similar to: DDM HID lights in...but confused..
Installed Smoked head lights and tail lights Ethan79 96-98 29 January 1st, 2010 07:59 PM
1984 SVO No Taillights, Gauge lights, Parking lights Mustanq SVO 2 January 2nd, 2009 11:12 PM
Where to buy saleen grill lights and turn lights 2005 madden 2005 - 2010 0 May 30th, 2007 10:54 PM
