Electronic Problems??kinda sorta?
Old May 7th, 2007, 07:08 PM   #1
Bies08 is on a distinguished road
Send a message via MSN to Bies08 Send a message via Yahoo to Bies08
So today i got my radar detector(thank you HMUSN) So i went to plug it in to the cigarette lighter down below the stereo and it didnt work. so then i figured it was a bad connection or didnt have it plugged in all the way. I went through the possiblities in my head and figured that it was a bad lighter or electricla spot. so i plugged it into the one in the console(idk if you guys have one but i do) i plugged it in..and it worked! when i got home i tore apart part of the dash and found out this:
If you aren't first.....your last!
Old May 7th, 2007, 07:12 PM   #2
ooh and the one thats has the circle around it(in blue) that is what im talking bout.....i think there is a wire missing???idk tho??? and the ones in yellow is what it should look like. how am i supposed to fix this??
Old May 7th, 2007, 07:15 PM   #3
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
probably a new connector spliced in. You could just line the inside of the one thats bad with a little bit of aluminum foil and then plug it back in. if your lucky it'll work and cost ya nothin lol.
New block with forged internals running 16psi, tuned by Lasota Racing
Too many mods to list...
3.73's and Truetrac Finally Done!
Old May 7th, 2007, 07:17 PM   #4
yeah but i cant find the other wire anywhere! thats why im asking you guys!
Old May 7th, 2007, 07:20 PM   #5
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
just stuff some metal in there like aluminum foil to complete the connection
NCMM #9
Old May 7th, 2007, 07:22 PM   #6
even without a wire going to anything??
Old May 7th, 2007, 07:44 PM   #7
anyone???will putting aluminum foil work even if its not hooked up to a wire?
Old May 7th, 2007, 07:55 PM   #8
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
If all else fails, you could run one of those outlet extensions from your console spot. Heck, it ends up being a good place to stash it when your not using it. I use my console for my phone charger and toss it in there when Im not using it. It may look shitty having wires running across your car like that though.
Old May 7th, 2007, 07:58 PM   #9
wait...what?? explain this again...a outlet extension??? the one below the cd player isn't working..soo woudlnt i plug this outlet extension into the arm rest thingy???
Old May 7th, 2007, 08:04 PM   #10
JASonic's Avatar
iTrader: 20 reviews
yea. Thats the one I use most. But do you want a wire running all up over your shifter n stuff. I guess you could run it down around the passenger side seat then up to where you want it.
I bought an extension at harbor frieght for like $4.99. It works great.
Old May 7th, 2007, 08:06 PM   #11
MM's Resident Ricer
2006 Scion tC
13.001@113
should work without a wire it will just complete the connection for a full circut since you still have power running to it
NCMM #9
Old May 7th, 2007, 08:53 PM   #12
it didnt work...i put a piece of aluminum foil in the hole and plugged it back in and i got nothing o ut of either the radar detector or my phone charger....
Old May 7th, 2007, 09:10 PM   #13
MM's Resident Ricer
2006 Scion tC
13.001@113
hmm can you find the wire it has to be there somewhere
NCMM #9
Old May 7th, 2007, 09:12 PM   #14
2000Si is on a distinguished road
Before you start ripping apart your connector, you checked the fuse, right?
Old May 7th, 2007, 09:21 PM   #15
haha...are there two separate fuses for each cigarette lighter. i dindt check fuses cuz i figured if one lighter didnt work and the fuse was fried then the other lighter woudlnt work...
wheres the fuses and i'll take a peak
Old May 7th, 2007, 09:22 PM   #16
I'd guess they'd be on the drivers side somewhere under the steering wheel on the bottom part of the dash. I don't have a V6 so i don't know for sure.
Old May 7th, 2007, 09:24 PM   #17
ok lets say the fuse is fried
why would one cigarette lighter work...when the other one doesn't?
Old May 7th, 2007, 09:26 PM   #18
Yea it just occured to me why would their be three prongs anyway. It takes power and ground to run a cigarette lighter. There probably never was suposed to be a wire running to that empty port in the connector. my guess is there's a fuse out or a short somewhere. test the wires and see if either of them have power. Maybe your cigarette lighter itself is bad
Old May 7th, 2007, 09:26 PM   #19
If they're on separate fuses, that'd explain it.
I have two lighters on my Windstar, each one has a fuse.
Old May 7th, 2007, 09:28 PM   #20
yep my dads titan has a fuse for each of the three cigarette lighters
Threads Similar to: Electronic Problems??kinda sorta?
ECTED, electronic locking re-end review. czwalga00gt 99-04 2 June 25th, 2007 10:19 PM
Car is Back ... Sorta .... MeZ 99-04 2 June 1st, 2007 09:52 AM
Electronic issues putermech Modular Mustangs 6 March 12th, 2007 11:09 PM
Installing An Electronic Boost Controller MikeyS281 Audio/Video 4 September 19th, 2006 04:49 PM
I'm here, sorta Jinxed New Members Introductions 6 August 19th, 2005 01:04 AM
