My top is leaky
My convertible top leaks a little bit around the back window area but i cant tell exactly where its coming from and it tends to add up so its like a pool sometimes in my car which is nice when you want to go fro a swim but sucks when you want to drive the car! any quick fixes for this or do i have to blow a wod of cash at some specialty shop??
Click The Picture!
The George Forman of Keepers
you have to find the leak. unless theres a hole in the material, its a seal. Take a hose on a dry day and try different spots. around the back window then the sides etc. Be carefull what you use to seal the hole becuase of the way the top folds down. You dont want to disrupt the folding or you could have worse problems later. The seals in the vert in my opinion are shitty. I have had some issues with pins across the top coming out and minor leaks. Make sure you keep it conditioned too to keep it soft and flexible... especially in Cleveland where the weather goes from bruning hot to freezing in a heartbeat. Try your hardest to fix small inperfections yourself becuase from my experience, roof repair is expensive. Better to spend your hard earned cash on a mod.
All else fails, go to the flats and get a beer!! |
lol ok sounds good
Click The Picture!
Leaks
I had the same Leaks. It comes from the seams by each of your window defrost Cords on the inside. I used silicone.
thanks, i'll check that out...but it seems to be coming from the very back of the top like where it is attached to the car, hopefully you're right though cuz thats an easy fix
Click The Picture!
Threads Similar to: My top is leaky
| leaky? | patwrecked | General Tech | 2 | September 2nd, 2007 08:08 PM |
| leaky | skid6 | 5.0 Mustangs | 8 | August 2nd, 2007 11:00 PM |
| leaky sunroof | 91bluestang | 5.0 Mustangs | 8 | July 8th, 2007 10:05 PM |
| leaky trans? | locknest | V6 Mustangs | 3 | February 27th, 2007 06:42 AM |
| Leaky injectors | Hotrodvdog | 99-04 | 2 | April 20th, 2006 08:28 AM |
