Loss of low end power
Old May 8th, 2007, 03:54 PM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
So every one says you lose power with LT's and exhaust and I have to say its def there...my power just comes higher in the rpm range. I raced a 5 speed 03 coupe last night It was even down low then I walked all over her in the upper rpms all the way untill I would let off...guess my car is gettin faster. Which brings me to my next point...I cant launch...If I hold the brake and gas to 1500rpm my tire spins...any ideas on that
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old May 8th, 2007, 03:58 PM   #2
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Re: Loss of low end power
hold the break harder or dont give it so much gas. or your breaks on your rear are worn to fuck and need to be replaced.
Old May 8th, 2007, 04:10 PM   #3
2000 V6
I tried that with brake pedal to the floor, because I thought I wasnt pushing it down enough...the car stops nicely tho
2000 V6 vert
Old May 8th, 2007, 04:13 PM   #4
Juggalo_X's Avatar
14+@Slow
dunno what to say i just have to have mine down about 25% and im good to pump up for the launch if i back off to about 15-20% break i start to do a burn out.
Old May 8th, 2007, 04:23 PM   #5
2000 V6
Damn...there must be somethind wrong here...my brakes dont squeak or sqeel or anything
2000 V6 vert
Old May 8th, 2007, 04:25 PM   #6
Juggalo_X's Avatar
14+@Slow
i have no idea maybe your packing more of a hp punch then i am whats ur mods bro im stock except for my sniper tune which BTW its a hell of a lot easer to burn out with i can feel the added power. and the throttle response. do you have gears? maybe thats why if u got 4.10's i can see you doing a smoke show pretty damn easily.
Old May 8th, 2007, 04:32 PM   #7
2000 V6
Just the mods in my sig...gears and t-lok are next I believe though
2000 V6 vert
Old May 8th, 2007, 04:37 PM   #8
Juggalo_X's Avatar
14+@Slow
your packing more HP then i am maybe thats got something to do with it.
Old May 8th, 2007, 04:51 PM   #9
2000 V6
Hmm could be...I heard these motors like to make TQ when modded too...maybe if I set the idle rpm to 1500 when Im racing I could shoot off the line
2000 V6 vert
Old May 8th, 2007, 04:53 PM   #10
Juggalo_X's Avatar
14+@Slow
that could work. damn high idle though
Old May 8th, 2007, 04:54 PM   #11
2000 V6
It would only be for racing...that way I could launch...
2000 V6 vert
Old May 8th, 2007, 05:10 PM   #12
tomzac is on a distinguished road
You could look into upgrading your rear brakes to the cobra size rotors which will give you a little more clamping effort to the rear tires. To do this mod I think all you need are the larger rotors, new pads, and an axle bracket at each side that relocates your stock calipers to use the larger rotors. There might be some small metal grinding too, but it's not that much if I remember right.
2002 Summer Beater
Old May 8th, 2007, 05:14 PM   #13
2000 V6
I would think it would fit with just 17in rims...
2000 V6 vert
Old May 8th, 2007, 05:17 PM   #14
Juggalo_X's Avatar
14+@Slow
should fit no problem.
Old May 8th, 2007, 05:28 PM   #15
2000 V6
I still gotta try the high drive idle RPM's too it might work
2000 V6 vert
Old May 8th, 2007, 05:42 PM   #16
Yes. The rear Cobra setup is smaller than front and the smallest front rim size is 17".
2002 Summer Beater
Old May 8th, 2007, 05:45 PM   #17
2000 V6
Nice...I got the rims...
2000 V6 vert
Old May 9th, 2007, 12:21 AM   #18
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
im lost so your trying to get a higher launch RPM? ... and you have had the bottom end tuned to the best of its ability? not just raise the RPMs but more fuel and air? and ... move the spark a bit?
Old May 9th, 2007, 12:36 AM   #19
punkafi888 is on a distinguished road
your rotors might be under spec?
Old May 9th, 2007, 12:41 AM   #20
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
bro im on 9in wide tires in the back and i can do a 20second burnout, launch at 1500 and i spin as well. tires or suspension work it the only way around it or t-lok/8.8 rear
my 60foots are so ugly cuz my spins and slow launches. theres no way around it aside from tires or t/lok or suspension
[SIGPIC][/SIGPIC]
Acmillr loves me
Threads Similar to: Loss of low end power
Could This Cause Loss Of Power VSR13 V6 Mustangs 24 December 14th, 2007 11:08 AM
Loss Of Power! Help Please! alamo11 V6 Mustangs 8 December 14th, 2007 09:34 AM
Loss of Power when a/c is turned on and more...help please! jsteves1313 V6 Mustangs 15 July 12th, 2007 08:08 PM
power loss? xedubx 99-04 16 June 20th, 2007 10:52 PM
Power Loss the hammr 5.0 Mustangs 8 August 17th, 2006 09:48 PM
