2007 Mustang GT/CS
So i removed spare tire.
Now what if i get a flat?
![]() 2007 Mustang GT/CS 5spd: Flowmaster hushpower axle back,O/R X pipe,JLT CAI,93 Bama tune..laser interceptor dual jammers, Escort Redline RD. |
#2 | |
use nvr flat it fill ups the tire and seal's em at the same time also have those 12v air compresors or w/e the voltage is
[8MINUS2]
Now what?
If you believe in God you pray If its not too bad you fix-a-flat it If you have a blow out then your screwed, see option #1
2007 Mustang GT/CS
okay. Thanks ill get some fix a flat. just wondering.
Those fix a flat cans dont seem big enough to fill a tire
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
MustanG_guy17, did you remove it for weight reduction?
The fix a flat stuff and similar leaves a big mess that someone has to scrape off your wheel... the guy at your local tire shop wont like you for a while
2007 Mustang GT/CS
yea i did why.. And maybe save some gas..
MustanG_guy17 have you considered a smaller dry-cell battery, lighter driveshaft, removing or replacing the bumper beams?
I am also interested in weight reduction and it doesn't seem to be a very popular topic around here. Thats why I asked. EDIT: for poor spelling |
#9 | |
2007 Mustang GT/CS
The George Forman of Keepers
Do you lose some traction without the weight in the back? Burnouts and donuts are probably easier
Yeah I wanna shed some pounds
#12 | |
#13 | |
I am not sure (mustang newbie) if anyone sells lighter weight bumper beams but you can probably remove 100lb just by replacing or removing those. The safety of your car might be affected tho. Also, you can do the rotors (to reduce unsprung weight) and driveshaft, but these tend to be more expensive mods. There are other benefits too. A CF driveshaft can allow you to increase your red line, supposedly improves vibrations, etc. http://www.acpt.com/driveshaft/driveshafts.html |
Don't remove the bumper beams if you get into a high enough speed wreck you very likely WILL DIE...... Keep it safe, the best idea would be lighter weight wheels, and all the standard stuff like rear seat delete and actually I would invest in a battery relocater instead of just i lighter battery.
ckthecerealkiller, the front bumper beam is rated to protect your radiator at crashes not exceeding 10mph or something similar (i can probably find you the exact speed). they will not protect you at 55+mph crash at all.
with that said, it is a personal choice that you have to make for yourself. |
#16 | |
when my wife got hit by "the crazy u-turn drunk" it was at about 20 mph. It put a hole in the bumper and bent the shit out of the fender and hood not to mention it popped a butt load of plastic push pins from the front end. My point is that that metal bumper didnt budge. There was NO major internal damage and my wife was ok. Had that bumper not been there, I know for certain there was enough energy at that low of a speed to blow that radiator, the fan and anything else up there. Your right, it may be preference and there's always someone willing to do something like that but I never would mess with that after what I experienced.
ja002gl, i am glad your wife is ok.
now consider side impact. if what ckthecerealkiller is saying was correct you would not stand a chance at side impact. so i would not go as far as saying your death is guaranteed. |
#18 | |
MM's Database Error
the beams are better then 10mph...every little bit helps...thats a pretty big piece of metal to only hold 10mph worth of impact
just a V6 with a bad belt slip under the hood |
Messing with the bumpers turns your car into a coffin. The bumper's primary job is to distribute large amounts of collision energy around the occupant through the subframe. As the energy travels from to back it's absorbed by designed weakness along the way. Without that design, a frontal collision could find the engine compartment in the backseat. From what I've read on the net, 100lbs of weight removal yields between .07-.1 second 1/4 mile time decrease.
2002 Summer Beater |
Threads Similar to: So i removed spare tire.
| Spare tire...... | 06GTMustang89 | The Clubhouse | 47 | October 12th, 2007 12:05 PM |
| Spare Tire Well Sub Enclosure | AtlanticBlue99 | Audio/Video | 20 | September 27th, 2007 12:26 AM |
| the spare tire | justinsstang | V6 Mustangs | 17 | May 9th, 2007 12:15 PM |
| 15" sub into spare tire of an 1989 mustang | kdizzle711 | Audio/Video | 7 | September 15th, 2006 10:18 PM |
