limited slip?
Old May 9th, 2007, 10:15 AM   #1
1997 Mustang GT
cpork is on a distinguished road
limited slip?
i bought my 2003 v6 convert about a month ago and i figured that it had the standard open diff...well i was burning out, figured id get a one wheel wonder...but when i launched, i looked behind me and saw two beautiful deep black tire marks...my question is how do i know if my car has a limited slip diff, i know i dont have t-lok though...
Old May 9th, 2007, 11:19 AM   #2
Mustang RacR94's Avatar
03 mach 1
13.2@109
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
t-lock
if it does posi burnots every time you most likely have t-lock
2003 Mach 1, 5 speed
U.S. Army - 11B
"And on the 8th day god created the infantry and all hell stood at attention"
Old May 9th, 2007, 12:36 PM   #3
Cesar2cool's Avatar
2003 Mustang GT
Cesar2cool is on a distinguished road
ive done a few 2 wheel burnouts..i think what it is..is that if you finish the burnout at an angle it drags your second tire..and thats what causes the 2 wheel marks..
Originally Posted by GearedGT View Post
Raw to fast, RAW to FURIOUS. I'M TO FAST FOR YA'LL MANG!!!!!!
goddamnit.
www.myspace.com/usmc03gt
Old May 9th, 2007, 12:48 PM   #4
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
when doing a born out all it takes is a shake of the steering wheel and both tires will turn. weight transfer will cause the second tire to slip and then it will smoke too ive done it a few times.
Old May 9th, 2007, 01:31 PM   #5
tomzac is on a distinguished road
Quick way to tell. Raise both back wheels off the ground. Turn one tire in the direction it would rotate to move the car forward. With a tlok, the other tire will rotate in that same direction (to move the car forward). If it rotates the opposite (to move the car backwards) it's an open (normal) v6 differential.
The True Trac differential will also act like an open dif. The safest way to check for that is to pull the assembly cover and do a visual.
2002 Summer Beater
Old May 9th, 2007, 02:48 PM   #6
1997 Mustang GT
tomzac, when i pull off the diff cover, what would a lsd look like versus an open diff?
Old May 9th, 2007, 03:05 PM   #7
Are you going to try raising the rear tires and turning them first? There's probably a very slim chance at best someone put a True Trac in your car.
2002 Summer Beater
Old May 9th, 2007, 03:36 PM   #8
Nick_Rapitis's Avatar
2000 Mustang Convertible
Nick_Rapitis is on a distinguished road
Send a message via AIM to Nick_Rapitis
if it doesnt do a two wheel peel everytime its not t-loc and the chance of it have a true trac differential is slim to none
Click The Picture!
Threads Similar to: limited slip?
Rumors (Limited Slip) mustangman03 V6 Mustangs 15 September 2nd, 2007 06:48 PM
Posi Or Limited slip 05MUSTANG4.0 V6 Mustangs 6 June 18th, 2007 11:49 AM
limited slip differential burlingtonNC98GT 96-98 6 April 17th, 2007 01:54 PM
Limited slip posi? JSmith9136 V6 Mustangs 4 February 2nd, 2007 08:20 AM
Limited Slip JRubin2000 99-04 6 September 21st, 2006 05:59 PM
