ARG!!
does my car take 10w20 or 10w30??? if it takes 10w20 like i think it does... where do i get the 10w20 royal purple?? all i can find is 10w30
i think its 30 weight
Click The Picture!
o yes... i have a 2000 stang v6... 5spd
http://www.mustangworld.com/ourpics/fcar/oilc1.htm ... this may have what u need... im not sure to b honest (i have never read it...lol)
5w20 and 10w30 is all they have... just to let u kno
The George Forman of Keepers
shouldnt you use heavier weight in the hotter months?????
my bad 638 i didnt even answer your question use 10w30... use a little more than 5 quarts
you should be using 5w30 if you car doesnt have to many miles, i'd say 75k mile or more use 10w30
what do the miles have to do with it?
+1 i been using 5-w30
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
hmmm im gona go and buy some 5w30... even tho i have 88k
Whats the diff between 5 and 10-w30
#14 | |
Your car looks real good for those miles... nice job. |
+1 ^^
i got a 2k1 and it takes 5w20
My Stallion is Bigger!
The newer model V6's are designed for 5w20. The tolerances in the motor are alot less so a thinner oil is required for proper lubrication. In the older pushrod motors however, 10w30 is reccomended by ASE. To explain the numbers so you know
10W30 10- This is the viscosity of the oil upon startup at relative temperature. 30- This is the viscosity of the oil after normal operating temperature has been obtained. Viscosity is (in laymans terms) how slick the oil is. You don't want too small a viscosity index or your engine will push it through the journals too quick and the motor will not properly lubricate and migrate heat. I use 10W30 in all my vehicles except my truck and I run a 10w30/20w50 mix because it has 300K on it, and the lifters need replacing but I am too lazy with my 4 jobs.
¡ʇsnq ɹo uʍop ǝpısdn
thanks... it has some issues... exhaust leak here... bad rotors up front... needs new paint... and hard water spots buffed out... new tint... front door speakers... lower main seal... nothin to big
#19 | |
MM's Database Error
i've always used 10w30 in my 04, should i use 5w20 like it says on the cap? like will the engine run more efficient that way, cuz i got an oil change thats gonna happen as soon as i get the time this weekend.
