6er exhaust manifold
Old June 2nd, 2011, 04:31 PM   #1
ItaliStang's Avatar
01 V6 convertible
too slow to try
ItaliStang is just really niceItaliStang is just really niceItaliStang is just really niceItaliStang is just really nice
Just out of curiosity, is there a common problem with the 99-04 sixxers having an exhaust leak on the manifold? I remember seeing a few problems in these threads a while ago, JaSonic's comes to mind and unfortunately i can't find his contact info anymore lol.
Haven't gotten the time to take a good look for it, but was just wondering if it's common. Is this something that can just be patched up with a weld?
Eagle Scouts or GTFO!
#8 in MM's coolest members
Originally Posted by 93hatch View Post
I voted for 93Snatch, because I don't even know what the fuck that thing on his avie is. Is it a Thunder Chicken?
its fucking zapdos show some goddam respect!!!!!
Old June 2nd, 2011, 05:14 PM   #2
Run ur car, not ur mouth.
SON1C's Avatar
2003 Sonic Blue 4.6L
SON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of light
yeah it is, passenger header, if i remember right ac coolant leaks onto it and causes it to crack due to temp change?
238rwhp/263rwtq
Drew's Build Thread
Old June 2nd, 2011, 06:04 PM   #3
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
its very common. one day i was driving and my entire manifold cracked all the way around and became separated from the rest of my exhaust pipe right before the flange.
so get it fixed now because i just didnt have the time to care about it until it finally broke all the way around.
2004 Bolt on & Cammed 3.9L V6
Old June 2nd, 2011, 07:02 PM   #4
Womkeith's Avatar
2002 Mustang
All day
Womkeith will become famous soon enough
Same exact thing here
Mavs 4 Blazers 2
Mavs 4 Lakers 0 SWEEP!!!
Mavs 4 Thunder 1 <---Going to FINALS!!!
Mavs 4 Heat 2 <------2011 NBA CHAMPS!!!
Old June 2nd, 2011, 09:57 PM   #5
ItaliStang's Avatar
01 V6 convertible
too slow to try
Makes sense, I'm guessing these can't be patched up with a weld? I'd prefer not to have to replace the whole manifold when I want to get rid of the car anyway.
I did notice my AC went out the same day I started hearing this problem (which was a year ago when it started )
Old June 3rd, 2011, 02:59 AM   #6
walt1120's Avatar
14.45 @95.8
oh yeah they can be fixed with a weld. have you, a friend or a shop just patch it up if its only a small leak.
mine was just very bad because i didnt get it taken care of sooner
Old June 3rd, 2011, 10:08 AM   #7
01 Slate Stang's Avatar
2001 Mustang
0 - 60 5 minutes
01 Slate Stang is on a distinguished road
i pulled mine off and welded them up no problem like 2 years ago... now im starting to get the same exhaust tick again .. sigh... time to pull off again and weld up somwhere else
Famous people walk on red carpet because they are rich... I walk on toilet paper because I'm the shit
Old June 3rd, 2011, 10:29 AM   #8
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
i put longtubes on and neglected to to do something to stop that water from leaking onto it, what was a fix that people do for this?
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old June 4th, 2011, 11:57 AM   #9
2000 v6 mustang
1slowv6 will become famous soon enough
IIRC it leaks out of a tube... so just re-route the tube with some like vacuum hose so that it drips away from the manifold
If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
Old June 4th, 2011, 10:42 PM   #10
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
I had the same problem, honestly I haven't used my A/C since.
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Old June 5th, 2011, 12:10 AM   #11
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
I have a set of stock exhaust manifolds for sale if anyone wants them <_<
Build Thread
Old June 5th, 2011, 12:24 PM   #12
Lumoon's Avatar
2001 Mustang V6
Its a V6
Lumoon is an unknown quantity at this point
You are sort of correct. At least on my car the AC compressor had a drip pipe that was like 1/2 inch long. I added some high temp vacuum line to it and ran it down to the ground away from the manifold. Haven't had a problem yet. Plus the water puddle after running the AC doesn't pool under the block now. I ran my pipe back to the passenger door.
Done so far:
3.73 w/ lsd rear end.
custom 91 octane tune by R Style Performance
rebuilt 4r70w
24% UDP pulleys
aluminum drive shaft
Windstar ready to be installed pending ported lower intake arrival
Old June 5th, 2011, 12:36 PM   #13
ItaliStang's Avatar
01 V6 convertible
too slow to try
I would assume it would be the condensation on the return line of the AC, so maybe just something to cover it would work enough.
So I'm guessing the spot to look is going to be right around where the header meets right up to the midpipe then? The EGR line is right below the AC lines, so I checked that over a bit, but didn't find anything.
Old June 5th, 2011, 03:38 PM   #14
Lumoon's Avatar
2001 Mustang V6
Its a V6
Delete that shit $12.57 at ford comes with a nice gasket and a cap for the header. Also makes doing LTs a lot easier.
Done so far:
rebuilt 4r70w
24% UDP pulleys
Old June 5th, 2011, 07:48 PM   #15
ItaliStang's Avatar
01 V6 convertible
too slow to try
I'm planning on just patching up this exhaust leak and selling the car, so I'm not worried about getting an EGR delete lol
Old June 6th, 2011, 11:43 AM   #16
2001 Mustang 3.8l
Italistang, i Laughed my ass off at the zapdos remark in your sig.
i will be working on this issue this week, i do not want a cracked longtube header.
Old June 8th, 2011, 09:36 AM   #17
shipwreck_98's Avatar
2001 Mustang 3.8
shipwreck_98 is on a distinguished road
There is a technical service bulletin, TSB 04-21-6, for that exact issue. You can take the car to a dealership and they can mount a drip shield over the manifold, or you can do it yourself. Unfortunately, it isn't free.
Old June 8th, 2011, 01:21 PM   #18
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
I have a spare exhaust manifold for whoever needed one.. Never lewaked
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Threads Similar to: 6er exhaust manifold
exhaust manifold 843marc V6 Mustangs 11 July 14th, 2010 04:12 PM
Need a new exhaust manifold rachidfunaki 2.3 Mustangs 15 May 31st, 2010 08:46 PM
Can anyone help me out with exhaust manifold? Rich J V6 Mustangs 10 March 9th, 2010 10:18 AM
exhaust manifold? DejaBlue87 V6 Mustangs 4 November 4th, 2009 06:25 PM
Exhaust Manifold joe_shizzle V6 Mustangs 9 April 12th, 2008 12:38 AM
