2003 Mach 1
12.7@107
![]() iTrader: 1 reviews
What size
How big is a 2003 V6 engine like not in liters but cubic inches. Also A GT is a 302 right? So what is a Mach 1 and cobra...are they still 302 just 32 valve instead of 16 valve?
232 is our ci
[8MINUS2]
V6 is - 232 - 3.8
GT/mACh1/Cobra - v8 - 281
what about the cobra r
My Stallion is Bigger!
1995 Cobra R Specs Engine 351 (5.8L) Windsor OHV V8Compression: 9.0:1Bore Stroke: 4.0 in. x 3.0 in. Intake GT-40 Heads and lower intake. Special Cobra upper intake Power 300 HP @ 4800 RPM365 lb-ft of Torque @ 3750 RPM Transmission Tremec 5-speed Rear end 8.8 inch with 3.27 gears Brakes Front: 13 in. vented cast iron disc, twin-pistoncaliperRear: 11.65 in. vented cast iron disc, single-piston caliperPower four-wheel disc brakes with anti-lock (ABS) Suspension Front: Modified MacPherson strut with separate spring on lower arm, 700/850 lbs./in.progressive-rate coil springs, adjustableKoni shocks; struts, front-strut tower brace,30mm stabilizer barRear: Rigid axle, four trailing links, adjustablevertical shock absorbers and horizontal axledampers, 200/260 lbs./in. progressive-ratecoil springs, 27mm stabilizer bar Wheels 17 x 9 in. 5-spoke cast aluminum Tires P225/45ZR-17 BF Goodrich Comp T/A Cooling Coolers for engine and power steering oil. High-capacity radiator Color White exterior with a beige cloth interior Emissions Certified and street-legal Gas Tank 20 gallons Deleted A/C, power windows, fog lights, stereo, sound deadening material Performance 0-60 in 5.4 secs; Top Speed 152 mph (limited)
2000 COBRA R ENGINE Configuration: Longitudinally mounted, 90-degree V8: cast-iron block: aluminum heads: forged steel crankshaft: billet steel connecting rods: forged aluminum pistons; McLeod aluminum flywheel Bore x Stroke: 90.2mm x 105.8mm Displacement: 5,409cc I 330cid Compression ratio: 9.60:1 Horsepower: 385 bhp @ 5700 rpm (estimated) Torque: 385 lb-ft. @ 4500 rpm Redline: 6500 rpm (6.800 rpm fuel shut-off: 7000 rpm ignition cut-off) Valvetrain: Double overhead camshafts: chain drive to exhaust cams, secondary chains from exhaust to intake cams: roller finger followers with hydraulic lash adjustment: ovate-wire, beehive-shaped valve springs: four valves per cylinder Intake valves: 2 per cylinder, 37mm head diameter Exhaust valves: 2 per cylinder, 32mm head diameter Ignition system: Distributorless coil-on-plug Fuel system: Sequential electronic fuel injection Intake manifold: Cast aluminum, tuned equal-length runners Throttle body: Single oval bore Mass-air sensor: 80mm Air filter: K&N cylindrical Exhaust manifolds: Stainless steel short-tube headers Exhaust system: Bassani X-pipe: production 98 Cobra catalysts: Borla mufflers and side-exit exhausts
2003 Mustang GT
GT's are 289..not 281..
#7 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
#8 | |
48.47@ 12.58
94+ mustangs
6ers = 232 8's = 281 |
#10 | |
48.47@ 12.58
don't forget Mr. GT500
2005 Civic
GAY!
also if i figured it right the 05+ 6ers are 240 or 245 or something 240ish because their 4.0l
slow car member twinky times two the stangs gone ![]() ![]() pypes mid muffler catback with their X-pipe In the top 20 cool peoples list on MM potsticker in training |
The George Forman of Keepers
3.8 liters is 2 gallons right?
You never hear someone say "hey, check out my cool 2 gallon engine". lol |
The man with the plan
+1
also, most urinals use 3.8 liters of water to flush..... coincedence?
Threads Similar to: What size
| maf size? | superman5.0 | 5.0 Mustangs | 5 | July 28th, 2007 08:06 PM |
| What size | scxc15 | V6 Mustangs | 24 | May 27th, 2007 05:09 PM |
| What size CAI | Zellanor | 2005 - 2010 | 1 | January 25th, 2007 10:18 PM |
