Run ur car, not ur mouth.
2003 Sonic Blue 4.6L
Brake Upgrade Parts+Install
really rotor and pad replacement/upgrade don't think i should upgrade calipers unless i need to?
what rotor and pad combo should i go with? i was thinking that i would go with the best cheap set i could find on ebay? I want to install them myself however, i'm never done this and tbh i'm not that good ![]() all advice/suggestions welcome and appreciated |
this one seems like the best bang for your buck? but i hope you get more than you pay for? Last edited by WLJohnson05; June 6th, 2011 at 11:53 PM. |
Dancing Naked In The Rain
A set of slotted rotors (zinc coated) and ceramic pads are pretty good. No need to upgrade calipers. Install is easy. Take the wheels off and each caliper is held on by 2 bolts (13mm I believe). Front caliper pistons simply press in but for the rears twist in so you'll need a caliper compression kit (I got one for $20 at Harbor Freight with multiple attachments) or the cube tool which is like $8. Caliper brackets have to come off and each one is only held on by 2 bolts. Pull those off then the rotors will slide right off so you can slide the new ones on. Bolt the caliper brackets back on, put a little brake grease on any part of the pads that touch metal, put the pads in, put the calipers on, bolt down the calipers, install the wheels, take the car off the jack stands, torque down the lug nuts, and go test out the new pads/rotors. Sometimes taking the cap off the master cylinder helps makes the calipers a little easier to compress.
#4 | |
2001 Mustang V6
Its a V6
Don't get the cross drilled Rotors I've found that they wear a lot faster than the plain slotted rotors. I also had a cross drilled rotor crack under a heavy brake load (8 car pile up in a fog storm) The slotted rotors allow air to pass easier and keeps the rotor cool which reduces brake pad stick and wear rates. The Zinc coating on them keeps the rust off. While your calipers are out might as well paint them.
Done so far: 3.73 w/ lsd rear end. custom 91 octane tune by R Style Performance rebuilt 4r70w 24% UDP pulleys aluminum drive shaft Windstar ready to be installed pending ported lower intake arrival |
yeah i was going to ask, how to paint them good and what paint?
and i've heard of the drilled cracking a lot so i should jut go with slotted rotors? |
2001 Mustang V6
Its a V6
Slotted is good.
And Advanced has caliper paint. Clean them up real good with a rough sand paper and wipe them off then paint.
2001 Mustang V6
Its a V6
I used 80 but that just because that's what I had in the tool box. I just sanded the rust off mine and gave them a good few coats of black. They looked pretty good for awhile but they need cleaned bad atm.
1999 Mustang V6
i got the ones from the second link and have had them for about a year now no issues. great stopping power too. very good bang for your buck i think
Resident badass
Slotted cool quicker. Solid last longer. Slotted will eat up the pads a lot quicker than what a solid will.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
when i replace mine im going with slotted, some guys go with both drilled and slotted but ive heard that it weakens the rotors.
i know stangmods has some pretty decent pricing on rotors and brakes, they sell some complete brake packages too.
2004 Bolt on & Cammed 3.9L V6 |
MM's Database Error
Truthfully, unless you have the power upgrades to need them, just go with your OEM stuff.
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
I believe having the holes drilling in the rotors makes them more prone to cracking. I've been running my drilled and slotted rotors for over a year with no issues, although I tend to engine brake quite a bit.
#15 | |
14.45 @95.8
![]() me cant do da engine brake
Tis a sad day
yeah i've heard that the drilled crack, a lot, especially on auto x which im hoping to do some of, and yeah im gonna go oem style but i figured one of those ebay packages would be the best deal?
'00 V6 Procharged Mustang
Go get your rotors measured and turned. There's no point in switching to probably lower quality rotors if yours are still good.
It'll turn this into like a $60 brake job.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). |
Threads Similar to: Brake Upgrade Parts+Install
| GT500 brake upgrade install | Apexodus | 2005 - 2010 | 29 | September 2nd, 2011 06:48 PM |
| v6 BIG BRAKE UPGRADE | NorCalWhtHrse | V6 Mustangs | 9 | November 21st, 2009 01:44 PM |
| Baer brake upgrade -- parking brake not working | spoulson | 5.0 Mustangs | 0 | September 30th, 2009 02:01 PM |
| Cobra brake or bullit brake upgrade | 97gtstang | 96-98 | 5 | May 14th, 2007 02:15 AM |
| Brake upgrade | My Red Coupe | Classic Mustangs | 0 | March 7th, 2007 07:26 PM |
