need help overheating problem
Old June 7th, 2011, 11:31 PM   #1
waylonsmith is on a distinguished road
i have a 2001 3.8 l mustang. i have checked and changed almost everything their is to check and change and i have still not solved my overheating problem. is their some kind of common problem people run into that nobody knows about. any questions comments concerns would be great thanks.
Old June 7th, 2011, 11:44 PM   #2
stephen has a spectacular aura aboutstephen has a spectacular aura about
Make sure there is enough coolant, that the system is bled out, and that the cooling system (especially the radiator) is not clogged. Also replace the thermostat. If it's still overheating you might want it checked for a blown head gasket or cracked head.
Old June 8th, 2011, 02:44 AM   #3
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
did you replace the thermostat?
if your still leaking coolant and you have replaced/checked everything in the coolant system you might have a warped head which is bad news for you. probably the worst possible scenario.
if your not leaking coolant, it could be something as stupid as your radiator fan not coming on and causing the overheating.
2004 Bolt on & Cammed 3.9L V6
Old June 8th, 2011, 12:35 PM   #4
AndyG47's Avatar
2002 Mustang V6
Slow
AndyG47 will become famous soon enoughAndyG47 will become famous soon enough
If you replaced the theromostat make sure you put it in right side up. I know it sounds stupid but sometimes it's the simple things that mess up.
Buddy did his plugs and wires on his Pontiac GTP - fired the car up and it was misfiring. I asked him if he crossed a wire and he said no. Half hour later after a phone call to another GTP guy he knows he finds he did cross a wire. All I did was look at him to which he responded "Don't even say it."
2003 F150 - 5.4L V8 4x4 - 109K hard miles & still going FORD Tough----2002 Mustang 3.8L V6 - Currently undergoing "I'm not 17 anymore" demoding
Originally Posted by OneShotOneKill View Post
this thread has more fail in the first 5 posts than all of the "what exhaust?" threads in the v6 section.
Old June 8th, 2011, 12:41 PM   #5
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
i had an overheating problem that did not happen on a regular basis, it was every now and the, i noticed the fan under the hood was not coming on, it ended up being a relay inside of a box that housed three other relays.
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old June 8th, 2011, 10:29 PM   #6
well i have checked the relays, replaced the radiator and theromostat, and radiator cap and have flushed the system several times. also if this helps i replaced two valves last fall in the car on the left head. they were both the back two exhaust valves. also did a full tune up before that if it helps to know, like replaced coil and all plugs and wires, oil etc. could i have done something wrong when i put the head back on?
Old June 8th, 2011, 10:37 PM   #7
also i have checked the fan its's also okay
Old June 9th, 2011, 12:54 AM   #8
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
Why did you have a head off?
Also, did you bleed all the air out of the system with the coolant flush?
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old June 9th, 2011, 10:02 PM   #9
had the head off because my car lost alot of power and was runnig really rough my father told me that it was the valves so i took it off and had to replace two. they were both not sealing all the way when they closed it ran okay after that but thats when the overheating issue started. i also did flush the system with coolant flush and lifted the front of the car up and bled it of any air then let it down to level ground and bled it again using the screw on top of the system.
Old June 9th, 2011, 10:20 PM   #10
Are you sure you got the head gasket in the right way around? The head gasket on some Ford engines (including the 3.8L V6) plugs off water passages in the front of the engine and leaves those in the back open. It's possible to get it on wrong and then there won't be proper water circulation to the back cylinders. Also did you replace the head bolts with new and torque them correctly?
Old June 11th, 2011, 11:21 PM   #11
i talked to the guys down at the advanced auto and they said try to replace the water pump since i have replaced everything but that so i did and that seems to have fixed the problem. it makes no since to me at all given that my old water pump seemed fine but it didnt over heat anymore. i was also wondering what the best mixture and best coolant to use in my car.
Old June 12th, 2011, 03:50 PM   #12
I've always used Prestone in a 50% mix.
Old June 12th, 2011, 08:49 PM   #13
Lumoon's Avatar
2001 Mustang V6
Its a V6
Lumoon is an unknown quantity at this point
Depends on the winter in your area. If you live some where it gets ridiculously cold I'd go 60% antifreeze 40% water in the winter and 50-50 in the summer, its what I run in the big rig if I know I'm going to be running up north. (Dakotas)
Done so far:
3.73 w/ lsd rear end.
custom 91 octane tune by R Style Performance
rebuilt 4r70w
24% UDP pulleys
aluminum drive shaft
Windstar ready to be installed pending ported lower intake arrival
Old June 14th, 2011, 04:20 PM   #14
ggipson79's Avatar
2003 Mustang Base V6 3.8l
ggipson79 is on a distinguished road
I have a 2003 3.8L auto.
The Relay he is talking about here is call the "CCRM" (cant remember what it stands for "Constant Cooling Relay Module" or something like this)- I know because I also had to replace it due to overheating. My fan would not come on (unless I ran a wire directly to my battery) and it was controlled by this doo-hickey. If you go to Ford they will want around $300 and they have been on back-order. I took mine off and called around to some junk yards and picked one up last year for about $40. TAKE IT WITH YOU and MAKE SURE TO MATCH UP THE #'S!!!! It is located under the front passenger-side fender. This thing controls EVERYTHING it seemed! I want to say it is about a 6 x6" square-ish box mounted under your fender-well (again, passenger side).
Then I started overheating again about a week ago. Turned out (so I dont have to go in and tell you that I replaced all the small stuff like thermostat,etc...) it ended up being my Alternator. It was not producing enough voltage/amps to power the CCRM, therefore it was not kicking in my electric fan.
Yea.....blew me away! (and so did the brand new price tag of $215.00) but I have had no more over heating AND other little things I noticed are also working (like my gauges were acting up a little, sometimes it acted like it didnt want to start).
2003 Base V6, 3.8L
Mello-Tone XPS Exhaust
17 x 9" Konig Beyond Custom Wheels
WANT: SCT Tuner (PM me if you all know of anyone), CAI, thats it for now...
Threads Similar to: need help overheating problem
Help overheating problem myfallenskys 5.0 Mustangs 11 May 26th, 2011 12:01 AM
overheating problem disturbdgt 99-04 6 April 15th, 2011 07:12 PM
overheating problem 94killer 94-95 1 June 26th, 2010 07:42 PM
Overheating problem help! chadscharged50 5.0 Mustangs 2 April 15th, 2008 08:53 AM
i think i may have an overheating problem baine21225 5.0 Mustangs 5 July 9th, 2007 02:40 PM
