Get me into the 12's
Old May 10th, 2007, 11:46 PM   #1
Replica R's Avatar
Replica R is on a distinguished road
I was adding on to another topic that was going and some guys recommend I start this topic so I wouldn't steal another persons topic. Yeah anyways, what do you think it would take to get a 1999 V6 into the 12 second range in the 1/4? I'm just shooting for 12's because I think that is respectable for a v6. I'm still gonna use this as my daily driver too, so I want it to be dependable. I know someone is gonna say to have the car blown, but I was gonna try a different route and go turbo with a street kit from TMA.
Friends Don't Let Friends Drive Rice!
Old May 10th, 2007, 11:48 PM   #2
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
put in a 4.2 a great tranny with 8.8 and all nitrous twin turbo and everything that can get on ur mind im too lazy to write exactly all the parts...
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old May 10th, 2007, 11:51 PM   #3
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
haha yea built block, forged internals to run gobs of boost. an 8.8 rear end definately. port and polish everything. i'm guessin probably 20psi to get into 12's
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Old May 10th, 2007, 11:52 PM   #4
¡ʇsnq ɹo uʍop ǝpısdn
twin turboed 4.2 L stage 3+ T56 and an 8.8
of course their is a shit ton of other stuff but those are the main components
Old May 10th, 2007, 11:52 PM   #5
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
If its an Auto -
A twin turbo kit
Fuel upgrades
Stall
12's
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old May 10th, 2007, 11:56 PM   #6
doesn't have to be twin
Old May 11th, 2007, 12:03 AM   #7
Replica R's Avatar
No it's a 5-speed manual right now. I think I might be able to do 12's with a good single turbo. An 8.8 with what 3.73's since it will be charged. I heard 4.10's will top you out before you get to the end of the track.
Old May 11th, 2007, 12:03 AM   #8
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
ok you wont need 20psi to hit 12s...you'd be hitting like 10s on a twin turbo set up with a built motor
you can:
power pak
bolt ons and nitrous
about $4k
4.2L engine
all bolt ons
4.10s with an 8.8
probably wont hit 12s with just that...most likely just mid low 13s
you'd need at least a 100shot
4.2L
11psi procharger
4.2L turbo kit
dont forget fuel upgrades on the s/c and tubro kits
[SIGPIC][/SIGPIC]
Acmillr loves me
Old May 11th, 2007, 12:04 AM   #9
00 V6 & 09 GT
yea if your running flat 10s or lower.
[SIGPIC][/SIGPIC]
Acmillr loves me
Old May 11th, 2007, 12:09 AM   #10
Replica R's Avatar
No I meant that I heard if your vehicle is not N/A, and is blown or charged, that 4.10s would make you top out before hitting the finish line. This isn't true?
Old May 11th, 2007, 12:09 AM   #11
i was assuming he'd be keeping the 3.8 block ass
haha j/k
also didnt factor in powerpaks in my guesstimate
Old May 11th, 2007, 12:12 AM   #12
00 V6 & 09 GT
actually you could just get a single turbo kit, 3.73s with a 8.8 rear and upgrade your injectors and fuel pump and run like 13psi. if your a good driver you should be able to kit 12s with that dependin on tires
vmptunning made 17psi with a STOCK BOTTOM end, and stock heads and cam at 450rwhp and nailed 10.98 in the 1/4 on slicks
with 13 psi on DRs or a decent set of street tires you should be able to hit 12s
[SIGPIC][/SIGPIC]
Acmillr loves me
Old May 11th, 2007, 12:12 AM   #13
No not unless you were runnin 10's like he said. it would have to be so fast that you could run out of gearing in the 1/4 mile which is only going to happen if you were able to run a 10
Old May 11th, 2007, 12:15 AM   #14
00 V6 & 09 GT
no
unless your car is hitting 10 flat, and even then i wouldnt worry about it as much but 9sec cars and lower dont run 4.10s or 4.30s
if your car was meant for drag and you wanted 12s
truthfully i think a 4.2L cam, p/p job, full bolt ons and some good heads with DRs and a 4.56 gear ratio
i think you could nail high high 12s like 12.9ish
[SIGPIC][/SIGPIC]
Acmillr loves me
Old May 11th, 2007, 12:16 AM   #15
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
That car had a **** load of suspension work didn't it?
Old May 11th, 2007, 12:17 AM   #16
00 V6 & 09 GT
yea and most people hitting 10s will only trap about 130sih 135mph
you shouldnt run out of gear then on a turbo or s/c set up....which would be the only way a sixer would see 10s unless they ran like a 300shot
9 second cars trap like 140-150
[SIGPIC][/SIGPIC]
Acmillr loves me
Old May 11th, 2007, 12:18 AM   #17
00 V6 & 09 GT
not sure, they dont give a whole lot of info on it. theres a video of it on their front page
[SIGPIC][/SIGPIC]
Acmillr loves me
Old May 11th, 2007, 12:23 AM   #18
GotBoost232 is on a distinguished road
Send a message via AIM to GotBoost232
since when did torres return....wow ive been australia tooooo long
stock 04 blue mach 1
Old May 11th, 2007, 08:18 AM   #19
Replica R's Avatar
Hey what is the purpose of an egr block off plate? Does it just stop hot gasses from re-entering the manifolds? What will it affect by doing this, like gas mileage or pressure problems with the engine. I know people are saying that it will cause the comp to throw a code and to just get a egr simulator to plug into the harness to fool the comp. But besides that is there anything major it would affect?
Old May 11th, 2007, 08:43 AM   #20
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
20psi your insane
my build that should put me in the 11's
moser 8.8 with eaton locker
lentech terminator AODE terminator tranny with 3500rpm stall (AUTO)
machined and rebuilt block with APR studs, performance head gaskets, and full forged internals
either tma kit, or custom rear mount turbo at 14-16 psi
full street/strip suspension
400rwhp build will put you in the 11's
of and for turbo your not going to want over 3.55 gears.
NCMM #9
Threads Similar to: Get me into the 12's
12's psycho bob 2005 - 2010 7 September 29th, 2007 05:10 PM
Finally got 12's 03 R Code Drag 24 May 20th, 2007 08:37 PM
Into The 12's notsoslo5.0 5.0 Mustangs 14 November 2nd, 2006 09:35 AM
how fast is 12's? w3s1c0a5t 5.0 Mustangs 23 August 12th, 2006 10:43 PM
I got my car into the 12's last night black04GT Drag 12 June 1st, 2006 03:33 PM
