1996 mustang
intake temp
So I have a computer diagnostic tool for my laptop so I was running the run time data with it and it says my intake temp is -40 degrees and while running tests it was like 100 degrees where is this sensor at I think it needs replaced
Resident badass
Right in the side of the intake tube. And yes. Either the Sensor is bad, or the computer is not getting a signal.
Find a trouble tree and get a DMM. It will involve using the DMM (Digital Multi-Meter) and Checking Either Ohms, Volts, or Amps at the connector. Compare the reading to the chart, and it will tell you the problem(s).
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
Threads Similar to: intake temp
| PI intake swap Coolant Temp question | Ruffellbaker | 96-98 | 5 | June 8th, 2011 12:20 PM |
| Temp sensor and Temp switch issue | tc3k101 | 96-98 | 2 | March 7th, 2011 10:16 PM |
| rough idle / no temp reading / high pitch whine after intake manifold replacement | brianallman | 96-98 | 1 | August 20th, 2010 02:16 AM |
| pi intake crossover temp sensor thread size | ColdSteel | 96-98 | 19 | March 6th, 2009 11:55 PM |
| intake temp. sensor | WilltheThrill | 4V / SVT | 3 | June 30th, 2008 04:37 PM |
