Battery Grounding Questions
Old June 11th, 2011, 01:37 PM   #1
Loki's Avatar
1996 V6
Loki will become famous soon enough
So, I know the stock ground for the negative battery terminal is on the passenger side, near the transmission (If I remember correctly). What would happen if you changed where you ground the battery? When I did my swap, I got frustrated trying to loosen the bolt on the cable and couldn't get a wrench to hold the bolt opposite side, so I just cut it and grounded somewhere else on the engine. I assumed that as long as the ground is on the engine, I would be alright. (Probably bad to assume things since I don't know much about wiring/electricity) Would it have caused any problems? (By the way, I am not having any electrical problems, so far as I know. I just want to confirm it's not part of my stalling problem. It'd be better to clear any possibilities from my head.)
Old June 11th, 2011, 01:42 PM   #2
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
It shouldn't be an issue as long as you used a crimp on style lug - none of that set screw crap that people use for installing amps. If you grounded it to a similar area on the block (beefy area without a ton of heat) you should be fine.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old June 11th, 2011, 01:45 PM   #3
Loki's Avatar
1996 V6
I'm uneasy about where I grounded it. It's on the front passenger side, near the A/C compressor if I remember right....I think I'm going to change it just for peace of mind and try to put it near where it originally was. Maybe it is part of my problem because I can see it getting some heat there....
Threads Similar to: Battery Grounding Questions
Grounding Points 95project 94-95 0 February 17th, 2011 11:22 PM
New Buyer. Couple of Tech Questions. Parts, White Color Suggestion, and battery q. crewxp V6 Mustangs 4 January 4th, 2011 07:15 PM
Can someone explain benefits of a grounding kit? Bajis 99-04 9 September 19th, 2010 01:47 PM
need help with grounding strap.. 97GT4.6 96-98 3 October 14th, 2009 07:03 PM
battery relocation and a couple other questions whitemustang02 The Clubhouse 14 February 25th, 2008 08:48 PM
