windstar system too lean?
Old June 11th, 2011, 11:25 PM   #1
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
I installed a windstar about a month ago. Got my mils in the other day for my longtubes. But my SES light just came back on throwing a system too lean code on both banks. Pretty sure I don't have a vacuum leak. Any ideas?
Build Thread
Old June 12th, 2011, 12:17 AM   #2
qwiksilvermustang's Avatar
1999 Mustang Pony
Not even currently moving
qwiksilvermustang will become famous soon enough
Can you hear any popping through the intake? Maybe the 02's are bad and are reading incorrectly.
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's
Old June 12th, 2011, 12:23 AM   #3
SlowSix's Avatar
2001 V6
15.47@89.57
That is what im thinking
Build Thread
Old June 12th, 2011, 03:08 AM   #4
SlowSix's Avatar
2001 V6
15.47@89.57
Sounds like I have a slight exhaust leak on the drivers side, would that cause a system too lean? I would think that would cause a system too rich code?
I'm gonna check for vaccum leaks tomorrow and see if I can figure out where my leak is coming from.
Build Thread
Old June 12th, 2011, 04:48 AM   #5
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
If you have an exhaust leak, it can pull air INTO the exhaust, then the o2s read it thinking it is too lean. Fix the exhaust first.
271rwhp N/A V6
Suck it.
Old June 12th, 2011, 11:10 AM   #6
SlowSix's Avatar
2001 V6
15.47@89.57
It sounds like its coming from my driver's side longtube. Should I pull it off and retighten it or what?
Build Thread
Old June 12th, 2011, 02:28 PM   #7
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Did you re-torque the bolts after a few drive cycles? With new headers you want to run it to op-temp, let it cool, and do this about 3-4 times, then re-torque the bolts.
271rwhp N/A V6
Suck it.
Old June 12th, 2011, 03:52 PM   #8
SlowSix's Avatar
2001 V6
15.47@89.57
I found a pretty large vac leak coming from where the spacer on the windstar mounts up to the manifold. Should fix it. Also retorqued my headers. Making a gasket now hopefully should fix my problem.
Build Thread
Threads Similar to: windstar system too lean?
System Too Lean Code 05roushmike 2005 - 2010 22 May 31st, 2011 07:00 PM
System too lean?? EvlS197 2005 - 2010 3 January 6th, 2011 09:05 AM
System too lean codes snake_fl General Tech 0 July 23rd, 2010 02:05 PM
P1074, system too lean (b2) YeloPony 99-04 11 April 9th, 2010 01:25 PM
System too lean (fail emissions) Pharoh V6 Mustangs 6 June 14th, 2007 07:29 PM
