2000 mustang v6
14.6@99.68
4.2 question
So my dad has an f150 and its been sale for a while and no one wants it (lol) so I was wondering sence its a 4.2 and its just a 3.8 block with a long stroke.....it shoulld just "drop" right in my car right....id have my dads truck for a complete donor
Bolt up to the engine mounts no problem? Bolt to tranny and drive shaft with no problem? And sence I wanna cam my car and sence its still a 3.8 block the lumpy cam will still work no problem right?? I just wanna make sure lol They seem like stupid questions but I wanna just make sure I know ppl will say if your gunna swap v6s why not just drop a 8...well that involves a lot of work....in my mind th 4.2 should just drop right in......and if you have a donor then bam no problem right...
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust Fixed clutch!!!!! "My mustang likes a good ol' fashion bowl of rice....especially fried" |
'00 V6 Procharged Mustang
There's really no reason to even want to do this. It's not like they really make much more power. That's going to be a lot of work and money(even if you don't pay for it his truck will lose a ton of value) for ~10hp.
I'm sure he can sell the f150 for more than what this would be worth to you.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). Last edited by mp4 player; June 12th, 2011 at 06:10 PM. |
2000 mustang v6
14.6@99.68
Then why do like 3 ppl have storked out 3.8s???
Because when you're actually building a block with forged internals it's just as easy to make it a 4.2. Yeah, there are some small gains from going to a 4.2 but none worth an engine swap and that amount of time or money.
Have you talked to your dad about this? I can't imagine him going along with scrapping his truck so your car can gain 10hp.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs. SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF). Last edited by mp4 player; June 12th, 2011 at 06:47 PM. |
2001 mustang
you may only get an extra 10 hp but you also get an extra 30+ more lb-ft of torque over the 3.8
![]() stroked. bored. cammed. ported. polished. 4.3 v6 ![]() my 2001 mustang build thread My 4.3 H/C/I v6 engine build |
[8MINUS2]
Ah, I like this post!
2001 Mustang V6
Its a V6
If your going to do the 4.2 swap you better go forged internals and get ready to go FI to make it worth the trouble of doing the heart transplant.
As for the lumpy cam I'm not sure if it'll work with the longer stroke of the 4.2l you may have to contact Comp Cams and ask them.
Done so far: 3.73 w/ lsd rear end. custom 91 octane tune by R Style Performance rebuilt 4r70w 24% UDP pulleys aluminum drive shaft Windstar ready to be installed pending ported lower intake arrival |
2000 mustang v6
14.6@99.68
yeah well wats ur take on it sence ill be getting a cam plus the 30ish tq from the 4.2..
Esg...opinon....? Also tq wins races
2001 Mustang V6
Its a V6
After I get a new house I plan on building a 4.2 w/ forged internals and going S/C .
To me its not worth it if ur not going FI. Now if ur going FI the its well worth the headache.
[8MINUS2]
1. I don't know why its a headache its pretty simple.
2. Some people missed the lesson in power under the curve. 3. Cam will work.
1999 Mustang Pony
Not even currently moving
![]() iTrader: 2 reviews
Agreed x10...
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's |
2000 mustang v6
14.6@99.68
....it sholu be relativle simple its still a 3.8 block so it sholu just drop in right....same engine mounts,....reuse stock heads (manafolds).....how r the cyl head on the 4.2 same or a little better
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
if your all about budget building this is what i would do...
pull the f150 motor and keep it all stock except throw a cam in it. get the comp cam max street/strip cam if your going n/a or get a blower cam if your going to supercharge it. drop it in your mustang and cut out under your scoop so the f150 intake will fit. then dyno tune the car after you decide if you want to do anything else (forced induction, nitrous..) take your old 3.8 and swap in the stock 4.2 cam that came out of the 4.2. (its a little better) then drop the 3.8 into the f150 and use it as your beater truck. ![]() btw, is the f150 auto or 5 speed?
2004 Bolt on & Cammed 3.9L V6 |
The soul stealing Ginger
do and supply write-up.
#15 | |
2000 mustang v6
14.6@99.68
Also my dads f150 is a stick shift
2000 mustang v6
14.6@99.68
You mentioned the stock f150 intake will not fir...I soon realized that....so I have a windstar intake from vap just waiting to be put on (which I'm waiting till I get my cam to do it all at once) the windstart will "botl" to the lower intake of the 4.2 like the 3.8...right?? And still clear stock hood...??
[8MINUS2]
Anything from the 94-04 RWD 3.8 and 4.2 blocks will fit any other 94-04 RWD 3.8 and 4.2 block ....
From vans, to mustang, single port or split, to supercoupe and everything in between.
2000 mustang v6
14.6@99.68
Sry esg for being fustrating I just wanted to make sure....
For who ever wanted a write up or w/e it will be a little bit ...at least a month and a half then ill make a new thread with an obvious title...lol Just for shitz and gigglesz lol Anyone wanna guess on rwhp/rwtq for a cammed 4.2 with pandp heads + windstar and mabey 1/4 mile time...will be hitting stripp in august...
Formerly 01silversixer
2001 V6
15.47@89.57
rwhp on a cammed 4.2 with ported heads and windstar?
<220 My guess is 208 rwhp, 225 rwtq |
#20 | |
[8MINUS2]
(mustangmike) has a dyno day less than a month, you can wait till then to find out instead of guessing.
Threads Similar to: 4.2 question
| quick question. fuel rail question on mark viii swap | Speedy1221 | 99-04 | 7 | October 12th, 2011 11:02 PM |
| cam with nitrous question, frpp manifold intake question | slater | 2005 - 2010 | 57 | November 14th, 2010 05:40 PM |
| Exhaust question and tuner question.....dont laugh lol | Drick | 99-04 | 19 | September 24th, 2009 03:42 PM |
| Exhaust question + supercharger (warranty) question | r00st | 2005 - 2010 | 2 | January 31st, 2008 11:07 AM |
| Muffler question (visual aspect) + Emblem question | warrior86 | Visual | 5 | November 20th, 2007 09:55 PM |
