clutch alignment problem
Old June 12th, 2011, 07:13 PM   #1
02edge's Avatar
2000 m112'd 3.8
02edge will become famous soon enough
this weekend I decided to change my tob and pilot bearing but after I put on the bell housing I realized I didnt put in that plug alignment tool and I noticed that compared to the splines in the middle of the clutch the pilot bearing was up way higher and I couldnt get the holes to match up so what should I do
Old June 12th, 2011, 07:25 PM   #2
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Get an alignment tool..
I have one sitting in my room if you don't have one.
271rwhp N/A V6
Suck it.
Old June 12th, 2011, 08:20 PM   #3
02edge's Avatar
2000 m112'd 3.8
I have one the plastic plug thing that comes with a new clutch?when do I put it in though right after I bolt it on the flywheel ?
Old June 12th, 2011, 08:29 PM   #4
stephen has a spectacular aura aboutstephen has a spectacular aura about
The tool goes through the hub of the disk and into the pilot bearing before bolting up the pressure plate.
Old June 12th, 2011, 08:30 PM   #5
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Put the flywheel on. Put the tool in the clutch disk and put the disk on the flywheel with the tool going in the pilot bearing. Put the pressure plate on and torque. Remove the tool by pulling it out.
271rwhp N/A V6
Suck it.
Old June 13th, 2011, 02:13 PM   #6
02edge's Avatar
2000 m112'd 3.8
well I got it aligned than went to put in the tranny and it slides in but stops about two inches before it hits the bellhousing so I pulled it back out and it came slightly misaligned and I fixed that again but is there any tricks to getting the splines to match up
Old June 13th, 2011, 08:22 PM   #7
Resident badass
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Wiggle the shit out of it. Nuff said.
271rwhp N/A V6
Suck it.
Old June 13th, 2011, 10:57 PM   #8
Try reinstalling the alignment tool and be sure it's aligned. I would use some kind of transmission jack to support the transmission, preferably one that has adjustments to tip the transmission in different directions. The input shaft has to be centered on the clutch disk hub and reasonably square to go in. Putting the transmission in gear and slowly turning the output shaft will help in engaging the splines. It's also good to put some high temperature grease on the input shaft. Some people use some long bolts as guides to align the transmission.
Old June 13th, 2011, 11:55 PM   #9
02edge's Avatar
2000 m112'd 3.8
i just need another set of hands and it should go in no problem cant wait to feel the difference new clutch lts egr delete programmer changed the tranny fluid bunch of little odds and ends
Threads Similar to: clutch alignment problem
Been wanting to ask this for a while, problem with alignment? GTPunisher 99-04 6 December 21st, 2010 09:39 AM
clutch problem zacfaughn 5.0 Mustangs 1 September 2nd, 2010 10:44 AM
clutch problem rainier446 99-04 1 December 13th, 2008 10:30 PM
clutch alignment tool silvergtstang99 99-04 2 March 21st, 2008 07:13 AM
1.5" drop alignment problem altwairqi 99-04 22 April 28th, 2007 01:42 AM
