Best camshaft but Still Passes California Smog?
Old June 15th, 2011, 03:41 AM   #1
Jetflo's Avatar
2001 3.8L w/ 5spd
Jetflo will become famous soon enough
It seems the modification is camshaft.
Question 1:
The engine has 120K miles on it. What must be replaced when replacing a cam in a high mileage engine?
Engine condition:
The engine runs great with less than 1 qt per 5000 miles oil consumption. It's been like that since I got the car at 60K miles. I've been changing with synthetic oil about every 5K miles with a Seafoam treatment every 30K miles. However, I'm a lead foot and I think the original owner was as well.
Question 2:
What camshaft would you recommend if you needed the car to pass tailpipe testing at idle and 3000 rpm on a roller dyno for say the next 120K miles?
Test Schedule:
2 yrs ago it was tested at 90K miles and was near zero on all measures. Next test is in August. I'd guess it gets tested every 35K miles.
Thanks,
Are you absolutely certain you're not pregnant?
Old June 15th, 2011, 03:58 AM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
Do cali laws allow cam change?
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old June 15th, 2011, 04:03 AM   #3
Mineral_Grey_Gt's Avatar
Mineral_Grey_Gt will become famous soon enough
I think so, as long they are CARB approved.
Old June 15th, 2011, 04:18 AM   #4
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
By that you'll never be able to cam your car.
Old June 15th, 2011, 04:21 AM   #5
Jetflo's Avatar
2001 3.8L w/ 5spd
They only do a visual check. It is probably hard to see a camshaft. I'd gamble an F150 cam would pass.
Is that the only option?
Old June 15th, 2011, 04:23 AM   #6
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
I would gamble that also, but its not worth swapping an f150 camshaft or anything remotely close. But I've heard the smog guys in cali are pretty smart so wouldn't a car that was loping give it away?
Old June 15th, 2011, 01:18 PM   #7
Trick Tuners's Avatar
KB'd GT
If it lopes at all, they will probably fail you. I'm not sure if any cam will pass the sniffer. I know that all cam swaps are not legal.
Old June 15th, 2011, 09:28 PM   #8
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
That sounds like a load of shit to me.
Other than that, I would not swap a stock cam for another stock cam unless the rest of the motor come with it. I'd give comp or crower a call and see what the'd suggest. Could even check with your local engine builder to see what type of cams theyre putting in motors that pass the sniffer.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old June 15th, 2011, 11:25 PM   #9
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Sniffer I'm not too worried about, I just hear Cali has some ridiculous inspection to where if a car sounds like it has an aftermarket cam they will start asking questions.
Old June 16th, 2011, 12:46 AM   #10
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
get a custom grind cam with a quiet idle. and try to get some air injection going after the o2 sensors to make the exhaust seem cleaner.
2004 Bolt on & Cammed 3.9L V6
Old June 16th, 2011, 01:21 AM   #11
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
4.2 cam for sell
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old June 17th, 2011, 01:39 AM   #12
Jetflo's Avatar
2001 3.8L w/ 5spd
4.2 cam for sell
I've been thinking about it Mike. The way this thread is going, it kinda seems like I should just swap in a used 4.2.
Wait, did I mention I have a forged super coupe crankshaft in my closet? I'm not sure a used 4.2 is the right move.
Old June 17th, 2011, 02:43 AM   #13
6ixer's Avatar
2000 mustang v6
14.6@99.68
6ixer is on a distinguished road
Get a used 4.2 from a f150 (like I am) keep the engine on the lift and buy your cam shaft...for me porlly lumpy cam or comp cams extreme engery street cam ...build the engine or tech just install the cam when its just on the engine jack/lift and when its done just drop it in
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust
Fixed clutch!!!!!
"My mustang likes a good ol' fashion bowl of rice....especially fried"
Old June 17th, 2011, 06:01 AM   #14
2004,1994,1967
14.37 @ 96
i think you should put in this 4.2 cam and go run it on a dyno and let us know what you make yup
I really think you should.
If it makes you more comfortable i do have the springs/retainers shouldn't be any different then ours, but if they are I have them. Just let me know and ill work out a price for ya.
I also have the lumpy cam spec, needs to be checked before i sell it though i think. Or atleast I want to get it checked.
227whp N/A V6
Old June 17th, 2011, 10:01 AM   #15
6ixer's Avatar
2000 mustang v6
14.6@99.68
Wait u just say u have a lumpy cam...or u think u do....find out pm the detail and ill buy it
Fixed clutch!!!!!
Old June 17th, 2011, 01:38 PM   #16
2004,1994,1967
14.37 @ 96
4.2 and lumpy cam
PMing now
227whp N/A V6
Old June 17th, 2011, 07:22 PM   #17
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Cam swap are legal provided the cam has a CARB number... however, as was already said, smog techs aren't gonna have you tear down the car so they can see the cam. Basically, if you have a cam that sounds non-stock and nothing else to "blame" the sound on, you'll need to have the CARB number from a legal aftermarket cam displayed on the firewall and make sure that whatever cam you swap in still passes emissions. What I've heard is that overlap is what kills you on the emissions test, so something like a blower cam will be your best bet.
O o
/¯/______________________
\_\
Old June 17th, 2011, 09:31 PM   #18
Jetflo's Avatar
2001 3.8L w/ 5spd
Rev,
I am glad to hear better news. Any blower cam you might recommend?
Thanks!
Old June 17th, 2011, 09:39 PM   #19
Man, I wish I could help with specifics, but I really don't know the V6 aftermarket that well.
O o
\_\
Old June 17th, 2011, 11:39 PM   #20
KB'd GT
For sure. A high lift cam with near stock overlap will pass the sniffer test, but won't sound super cool at idle. When you get a heavy lope with large overlap, the exhaust will suck out some unburnt fuel and you will fail HC.
Threads Similar to: Best camshaft but Still Passes California Smog?
Passing smog in california jamesxcore4 2005 - 2010 14 March 5th, 2010 11:02 AM
need help before going to the California Smog Referee mat82284 99-04 4 December 28th, 2009 04:25 PM
California Smog DblAughtGT 99-04 33 March 16th, 2009 12:27 AM
do shorty h pipes pass smog in California 2002 Roush Modular Mustangs 9 June 17th, 2008 03:39 AM
Smog Testing In California chris1 99-04 33 November 29th, 2007 04:48 PM
