Twisted chassis or serious alignment issues?
Old June 16th, 2011, 05:53 PM   #1
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
Angry
While i was waxing my car the other day i noticed that there is a significant amount of spacing between my hood and headlight on the drivers side over the passenger side. the rear is the opposite of the front. The car was rear-ended before i bought the car but the car did not have a salvage title, and when my sister was driving it one night she hit someone but it was at like 10 mph and there was not much damage so she didn't fix it . I was hoping that it was just horrible alignment instead of the body being twisted. it passed inspection yesterday so i know that the headlights are in the correct position.
Passenger side: 0616111557a.jpg picture by Green_6er - Photobucket
Drivers side: 0616111557a.jpg picture by Green_6er - Photobucket
Old June 17th, 2011, 02:01 AM   #2
Jetflo's Avatar
2001 3.8L w/ 5spd
Jetflo will become famous soon enough
It sounds like it may not be cosmetically correct but are there any symptoms of poor alignment?
I'm not sure why you are worrying about unibody or sub frame damage at this point.
Are you absolutely certain you're not pregnant?
Last edited by Jetflo; June 17th, 2011 at 02:02 AM. Reason: change from "frame" to "unibody or sub frame"
Old June 17th, 2011, 02:18 AM   #3
Needs 2 cylinder bolt on
Mach Stang's Avatar
'03 Mustang V6
It's a six so what do you expect?
Mach Stang is a jewel in the roughMach Stang is a jewel in the roughMach Stang is a jewel in the rough
why wouldn't he? it could easily get worse if the frame is twisted.
can you post a front end view of the car?
"you're alive for a reason, DON'T GIVE UP"
Originally Posted by SoMDWhite03GT View Post
Going down to NC for the NASCAR race!
When I seek that kind of entertainment I sit by the the red light near my house and watch all the cars turn left
Old June 17th, 2011, 06:03 AM   #4
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
thats what im thinking, more views ... these pics are useless lol
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old June 17th, 2011, 08:37 AM   #5
Six Banger's Avatar
2001 - 3.8
Six Banger has a spectacular aura aboutSix Banger has a spectacular aura aboutSix Banger has a spectacular aura about
Nothing to worry about, my cars the same way and its never been in an accident. Alignment would mess with your tires, not the body of the car, and a twisted frame would be noticeable driving it.
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome.
Old June 17th, 2011, 01:52 PM   #6
Green_6er's Avatar
2000 Mustang 3.8
well the steering wheel jumps really badly at low speeds and the whole car vibrates at high speeds. the front bumper looks like it doesn't line up with the hood well either. when i pull the wheels off Tuesday for paint prep i'll take it all apart and see whats wrong. i had the front bumper off before to repaint the grille in it so i might have gotten the bumper back on incorrectly or something. i will take a front end pick in a pit.
Old June 17th, 2011, 02:55 PM   #7
Green_6er's Avatar
2000 Mustang 3.8
i meant like alignment of the body panels not the alignment of the wheels XD. but i just went out and took the front bumper off and the headlights out and i found out that the car has been in a few wrecks and the front bumper is just drooping pretty badly. for the 2 years that my sister owned the car tore the stock front chin spoiler that was held under the front bumper and the bumper is drooping from those holes, so nothing to worry about.
Old June 17th, 2011, 09:45 PM   #8
Jetflo's Avatar
2001 3.8L w/ 5spd
Are the wheels straight and balanced?
Even if the car is WHACKED you can still put on a set of caster camber plates and get it aligned pretty well.
Is the wheelbase the same on each side? That'd give you a clue if the chassis is bent or not.
Given that few of us on this forum are certified in measuring car wheelbases, you're probably good for maybe + or - a quarter inch. So if you measure the two sides within one half inch, then odds are slim anything important is bent.
Get an alignment done and look that the thrust angle. That is another good indicator of how "straight" your car is.
Good Luck!
Old June 17th, 2011, 09:54 PM   #9
Green_6er's Avatar
2000 Mustang 3.8
i know that the wheels are straight because when i had my exhaust done i had all 4 tires replaced and everything aligned, and that was like 1-1.5k ago. im guessing that it is just worn-out rubber in the suspension? because after about 35mph the steering wheel stops jumping, so i have no clue.
Old June 17th, 2011, 10:09 PM   #10
Jetflo's Avatar
2001 3.8L w/ 5spd
Can you bring it back to the tire store? At <2K miles it seems more than fair to ask them why the tires they sold you are behaving this way.
Old June 17th, 2011, 10:21 PM   #11
Green_6er's Avatar
2000 Mustang 3.8
it started before i got the tires, i was hoping that the new tires and alignment would ix it but it didn't. I went through and i tightened all of the lug nuts down on it and it stopped for like 20 miles then it started again. On my back right wheel when i bought the car it only had 4 lug nuts on it because one of the studs was basically rusted away, do you think that could be the culprit?
Threads Similar to: Twisted chassis or serious alignment issues?
issues with getting alignment... please help(eibach suspension) sj408 99-04 9 January 6th, 2011 04:59 PM
2.3l chassis vs. 5.0 chassis question dmanflynn 2.3 Mustangs 11 September 12th, 2010 12:21 AM
Trick Flow Twisted Wedge Fast As Cast vs Trick Flow® Twisted Wedge Street Timm10221 5.0 Mustangs 16 June 16th, 2009 01:41 PM
Alignment issues bad mantis3567 99-04 21 January 7th, 2009 11:09 PM
Door alignment and weatherstrip issues extropy Classic Mustangs 5 September 6th, 2008 05:11 PM
