1996 V6
CEL P1131 code
Hey, I finally popped up a code RIGHT before I was going to go through emissions. Lol. It's P1131, I think it said I'm running lean. I've been thinking about this for a couple days now, but when I ordered my tune a couple months ago, I got it for 21 lb injectors, because thats what I read the 99's used, but a couple days ago, i ran into somewhere saying they were 19lb. Could this be my problem? Being tuned for the bigger injectors? Which is right for 99, 21 or 19? Any help or input appreciated!
2001 Mustang
0 - 60 5 minutes
19 LBS for 99 model
Famous people walk on red carpet because they are rich... I walk on toilet paper because I'm the shit
Formerly 01silversixer
2001 V6
15.47@89.57
Yeah that is definitely something I would fix. If you clear it and it comes back after that check your car for a vacuum leak.
1996 V6
Son of a bitch. Lol, I thought so. Thanks, guys!
Oh, Silver, I definitely have no leaks. When I did my swap, I replaced all the gaskets and cleaned everything up inside. I'll double check just in case, but I'm pretty confident on my work. Cars running great, tho! =] Feels good to be driving again |
14.37 @ 96
O2 sensor bank1 sensor 1
1996 V6
I know that, but considering what I mentioned in the first post, im pretty confident thats the base of my problem & why it threw the code
14.37 @ 96
yup, re order a tune for 19#
1996 V6
Already done =] I probably shouldn't drive it in the meantime. This is really killing me, I just want to drive my car already >_< The CEL did turn off when I drove a bit more aggressive, but I know the problem is still there. SO, I guess I wait another week. Lol. Thanks for the input, guys
2000 GT 'vert
Can't you reapply the stock tune for now?
1996 V6
Stock tune would be worse! Lol, I have a 96 with a SP swap. Stock tune is 14lb injectors and I run extremely rich!
2000 GT 'vert
Ahhh, well that bites!
1996 V6
Okay, so I switched the tune for the correct injector size & I am still getting the code. It's stopping me from passing emissions. I'm thinking that the injectors might be a little clogged (They are from the jy engine, which had dirt clumps on top of the pistons when I took it apart. Lol). I think I might just try some injector cleaner and see if that helps. Just something I noticed, though, is that it shuts off when I drive aggressive. That's why I'm thinking it may be the fuel injectors. More fuel pressure maybe helps it flow better?
Threads Similar to: CEL P1131 code
| Dtc code p1131 and p1151 keeps coming up | Mustang03 | 99-04 | 21 | October 6th, 2011 11:15 AM |
| P1131 code | bigboy05 | 99-04 | 3 | April 27th, 2011 11:04 AM |
| Code P1131 | tweety_5150 | 99-04 | 7 | January 27th, 2011 07:14 PM |
| OBD II code p1131 | stephen | V6 Mustangs | 0 | January 20th, 2009 08:29 AM |
| p1131 | Blackblurr_00GT | 99-04 | 13 | March 2nd, 2008 10:33 PM |
