Rear Brakes Locking Up?!
Old June 19th, 2011, 10:18 PM   #1
1998 Mustang V6 'Vert
NightmareX23 is on a distinguished road
Hey guys,
So I recently did an overhaul on the rear breaks (pads, rotors, brackets, and calipers) and since then whenever i pull the ebrake to put my top down (v6 vert) the rear brakes lock up and dont release until a long time later. A friend said that its possible that it just needs new lines and hoses. Any suggestions and tips?
Thanks,
JD
Old June 19th, 2011, 10:23 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Sounds like there is something wrong with your E brake. That is on a cable so it should be easy enough to fix. Welcome to the forums.
Old June 20th, 2011, 12:06 PM   #3
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Did you use the caliper tool to spin the pistons back into the calipers when you did your overhaul, or did you attempt to compress the pistons in with a c-clamp? If you did the latter, you may have damaged the calipers. It's a common mistake, which is why I ask.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old June 20th, 2011, 01:08 PM   #4
craigdavey's Avatar
craigdavey is on a distinguished road
+1 to this...I didnt know that they turned in at first either but luckily i didnt try too hard before i googled it and found out.
2004 3.9L Vert (sold)
Old June 22nd, 2011, 06:04 PM   #5
Thanks for the generous hospitality... About the calipers, to tell ya the truth a family friend thats a master mechanic did my rears for me, as I have little mechanical knowledge, I'm pretty sure he used a caliper tool. The e-brake being the issue makes a little more sense cause my 6er is A/T and I never really use it. Can someone point me to a DIY or info on fixing/replacing the e-brake?
Old June 22nd, 2011, 09:54 PM   #6
2000stallion's Avatar
2000 Mustang
slow@slow
2000stallion will become famous soon enough2000stallion will become famous soon enough
i had to get a tool for mine after my rear end swap, and ended up replacing the pass side master cylinder
For Sale:
99-04 smoked tail light covers
Threads Similar to: Rear Brakes Locking Up?!
brakes locking up wolfeman04 V6 Mustangs 13 June 13th, 2011 03:40 PM
rear wheels locking up mrblueoval 99-04 2 February 26th, 2011 05:59 PM
06 Rear Brakes Help! Bubba42003 2005 - 2010 V6 4 November 28th, 2009 05:54 PM
Rear brakes acobraman 4V / SVT 4 May 31st, 2009 06:59 PM
rear disk brakes and rear end extropy Classic Mustangs 3 August 11th, 2008 06:41 PM
