2000 V6 Mustang -> 1997 Cobra Cluster Swap
LinkBack (2) Thread Tools
Old June 20th, 2011, 06:16 PM   2 links from elsewhere to this Post. Click to view. #1
shadowslayer460 is on a distinguished road
Just wondering if i could swap the cluster out of a 1997 cobra mustang into my 2000 v6.
If not, which will work? I love the look of the cobra clusters but for my year the only cobra was the cobra r and that cluster runs 600+
Thanks
Old June 20th, 2011, 06:17 PM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
You could, getting it to work would be a different situation all together.
99 cobra / 01 cobra
or
03 / 04
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old June 20th, 2011, 06:20 PM   #3
So your saying that the 99 or 2001 cobra and the 2003 and 2004 would work better?
What would be the trouble in swapping them, basically after buying the cluster what would it come down to with making it work properly
Old June 20th, 2011, 06:21 PM   #4
honestly i don't think they will fit (97 cobra that is..NE cobra is a different story), but if you like the look of a cobra cluster and don't want to spend that much money look for a used set of "el glow" gauges...that's what i did on my old v6
the reason i say used is because nobody makes them anymore...but maybe someone on here may know a link i haven't seen. if so that's great because i'd love another set
Old June 20th, 2011, 06:24 PM   #5
That looks great, ill have to track down one though.
What trouble comes with making it work in my car though
-mileage
-ect ect
Old June 20th, 2011, 06:26 PM   #6
-mileage
-ect ect
if, and i mean if you can find el glows then they just lay over the factory gauges...you remove the oe bulbs, and wire the new covers into the gauge clusters power line..it takes all of 15-20 minutes to do it all
if not and you have the cash you can look into autometer gauge clusters...their pricey but give the look you want
Old June 20th, 2011, 06:26 PM   #7
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
97 cobra's had the mechanical odometer for one thing
Build Thread
Old June 20th, 2011, 06:28 PM   #8
Ok, if i was to purchase the 2003 cobra cluster though what trouble comes into swapping it?
How do i get things to match
Old June 20th, 2011, 06:30 PM   #9
a dealer or tuner would need to recalibrate the gauges for the sensors in your car for one...the pats system may be affected here but i don't know for sure since i've only used slips and not a full swap...someone else will need to jump in for that answer
Old June 20th, 2011, 07:37 PM   #10
Lumoon's Avatar
2001 Mustang V6
Its a V6
Lumoon is an unknown quantity at this point
I think PATS would need to be bypassed. I know when my friend did his to the GT guages it was bypassed at the dealership.
As for the 97 Cobra, it has the mechanical odometer and not the digital one, so that's one issue, its also got the separate trip meter so thats number 2, I also think the connector from the needle to the actual device that turns the needle is different. Hell it may even be a different brand...
To be safe stick to the same generation of mustangs, example 99-04 and the rest.
Done so far:
3.73 w/ lsd rear end.
custom 91 octane tune by R Style Performance
rebuilt 4r70w
24% UDP pulleys
aluminum drive shaft
Windstar ready to be installed pending ported lower intake arrival
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/223140-2000-v6-mustang-1997-cobra-cluster-swap.html
Thread Swapping in a 99-01 Cobra guage cluster questions | Forums at Modded Mustangs | BoardReader This thread Refback May 8th, 2012 10:31 PM
Thread 2000 V6 Mustang -> 1997 Cobra Cluster Swap | Forums at Modded Mustangs | BoardReader This thread Refback April 19th, 2012 05:51 PM
Threads Similar to: 2000 V6 Mustang -> 1997 Cobra Cluster Swap
1997 Mustang gt engine swap?? 97mustangJ 96-98 9 May 17th, 2011 12:08 AM
cobra dash cluster swap! oifdoc 99-04 0 February 14th, 2011 05:11 PM
Cobra cluster swap ssprofession 96-98 1 January 28th, 2009 03:02 AM
1997 mustang cobra deedub97GT The Clubhouse 19 July 31st, 2008 02:26 PM
Swap 2000 Motor To A 1997? zimaad 96-98 4 December 8th, 2007 11:46 PM
