#21 |
Resident badass
710 if the take the 3.8 as a core. 910 if not. And the use clevite rings and bearings.
If they won't take my core then I'll just get some Hi comp pistons.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. Last edited by Mr. Red Pony; June 21st, 2011 at 11:38 PM. |
#22 |
2000 mustang v6
14.6@99.68
Well right now I have a 4.2 just sitting in my garage on a engine lift or w/e u wanna call it....bout to get my heads p and p and evenually ill order the lumpy cam from ssm ...with windstar.....mike do u have pan p head or anything else??
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust Fixed clutch!!!!! "My mustang likes a good ol' fashion bowl of rice....especially fried" |
#23 |
Resident badass
I think he has stock heads. I'm doing the equivalent of stage 3 heads. Full gasket match/port with bowl work, milled, comp (3-angle) valve job, stock sized valves, and LS6 yellows. With matched/port lower and windstar. And to top it off the comp cams MAX cam.
![]() 271rwhp N/A V6 ![]() The Name is Danny. I'm a GM Technician. Suck it. |
#24 |
2000 mustang v6
14.6@99.68
Comp cams max/xtreme cam is the same as the lumpy isn't ...well the lsa is diff by 4 but lol
#25 | |
1999 Mustang Pony
Not even currently moving
![]() iTrader: 2 reviews
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's |
#26 |
2000 mustang v6
14.6@99.68
Ok wat is a 3 valve angle job or w/e I heard that like 2 times.....wat is it and wat does it do ect
#27 |
Resident badass
You tube/google it.
Threads Similar to: Whats the difference?
| whats the difference ?? | SilverGT04 | 99-04 | 15 | June 15th, 2009 05:50 PM |
| whats the difference between... | joejoe8455 | 5.0 Mustangs | 25 | April 15th, 2009 07:07 PM |
| Whats the difference? | seneye | V6 Mustangs | 17 | April 12th, 2009 10:56 AM |
| Whats the difference? | usafimj | 2005 - 2010 | 3 | September 26th, 2007 11:38 PM |
| whats the difference?? | 5litercobra | 5.0 Mustangs | 2 | August 27th, 2006 12:45 AM |
