crank no start
Old June 21st, 2011, 02:20 AM   #1
2000 mustang v6
belair88 is on a distinguished road
crank no start
got a 2000 v6 3.8 mustang cranks no start suddenly after leaving a party...the theft lite flashes but idk if thats it....we replaced the coil pack after a mechanic told us it wasnt gettin any fire..still not working...but what i was wondering is this....after we tried resetting the security system by leavin the battery disconected for a few mins and after we connected the battery the wipers started going...and the keys werent even in the ignition.....anyone have a similar problem? hoping its something we can fix without goin to a dealership ..
Old June 21st, 2011, 02:48 AM   #2
6BangEr's Avatar
2000 Mustang V6 3.8
6BangEr is a jewel in the rough6BangEr is a jewel in the rough6BangEr is a jewel in the rough
Have you checked all the cylinders for spark? Could also be a fuel issue. You might have spark but nothing to ignite.
nothing new to you mcqueen.
Jizz and anal juice are your specialty
don't you have a tongue that you can punch a fartbox with?
Old June 21st, 2011, 02:49 AM   #3
6BangEr's Avatar
2000 Mustang V6 3.8
Oh and
Old June 21st, 2011, 02:57 AM   #4
qwiksilvermustang's Avatar
1999 Mustang Pony
Not even currently moving
qwiksilvermustang will become famous soon enough
The pats system is keeping the ignition from firing.... you need to have that fixed..
lt's,o/r h, flow 40's, egr delete,windstar w/65mm tb,UDP, sniper tuned
Need to install: 4.2 crank,.030 silvo's,268hr112 cam,RR's,comp 915's
Old June 21st, 2011, 03:03 AM   #5
6BangEr's Avatar
2000 Mustang V6 3.8
shouldn't it disable if he puts his key in? (granted it's not a copy and is chipped)
Old June 21st, 2011, 03:06 AM   #6
1999 Mustang Pony
I would think it would, i'm wondering what kicked it off in the first place. Maybe he he puts the key in and waits a minute to see if it'll go off.
Old June 21st, 2011, 03:22 AM   #7
6BangEr's Avatar
2000 Mustang V6 3.8
My theft light always blinks as well. @OP do you press the button on your keyfob to unlock doors or do you turn the key in the door?
Old June 21st, 2011, 03:27 AM   #8
2000 mustang v6
key in door
Old June 21st, 2011, 03:28 AM   #9
6BangEr's Avatar
2000 Mustang V6 3.8
do you have the keyfob? if so try to arm the alarm. Press button twice until horn honks. Then unlock it using the key fob
Old June 21st, 2011, 03:33 AM   #10
2000 mustang v6
no i only have the key...does the windshield wipers and radio working with no key in ignition sound to be anything related to this
Old June 21st, 2011, 03:35 AM   #11
6BangEr's Avatar
2000 Mustang V6 3.8
I'm not sure. I know that pats system fucks with your electrical so it very well could be. try turning the key in the door twice (unlock it turning key twice in same direction)
Old June 21st, 2011, 03:40 AM   #12
6BangEr's Avatar
2000 Mustang V6 3.8
also turn the key to on position in the ignition. Keep an eye on the theft light. should flash and then stop after 15-20 seconds. Try to turn ignition over when light turns off
Old June 21st, 2011, 03:44 AM   #13
2000 mustang v6
ok i will try tomorow im stuck at work rite now
Old June 21st, 2011, 11:20 AM   #14
Jailbait till 2013
whyxitx's Avatar
2001 V6 / 94 Z28-gone
0-60 in -10.3
whyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to beholdwhyxitx is a splendid one to behold
Yeah, the theft light blinking is sometimes normal for when you try to start it and it wont. When my battery died the theft light blunk and i was flipping out for a good while until i came back outside and realized that it was just a dead battery.
Like the others said, check for cylinder fire, your fuel, your spark plugs. Whatever else you can. Because if it's a PATS it's going to be a pain in the ass to get your car started again, and you're more then likely going to have to go to a dealership to get the PATS disabled.
I Removed My Door Dildos
Originally Posted by bullitt1680 View Post
Whyxitx's sixxer is so fast that the side scoops come off when he drives. How could anyone say that isn't fast.
2001 V6 - Needs faster engine
1995 Human - Needs BJ
Old June 21st, 2011, 11:25 PM   #15
2000 mustang v6
checked everthing today it has to be the pats...great SMH
Old June 21st, 2011, 11:31 PM   #16
6BangEr's Avatar
2000 Mustang V6 3.8
do you have the right key? (one with the chip)
Old June 22nd, 2011, 12:05 AM   #17
2000 mustang v6
yeah its the same key i used since i bought it
Old June 22nd, 2011, 12:23 AM   #18
6BangEr's Avatar
2000 Mustang V6 3.8
do you have a spare key? maybe the chip went out in yours
Old June 22nd, 2011, 12:25 AM   #19
2000 mustang v6
no dont gat a spare...
Old June 22nd, 2011, 12:51 AM   #20
6BangEr's Avatar
2000 Mustang V6 3.8
well.. sorry to hear. Looks like will have to go to a dealership. (suggestion)
Threads Similar to: crank no start
Crank but no start RoushRacing99 2.3 Mustangs 7 February 6th, 2011 07:51 AM
crank-no-start help. pber13 99-04 12 April 22nd, 2010 07:59 AM
Crank but no start 817B!GT3X 5.0 Mustangs 12 September 18th, 2008 07:59 AM
Crank but no start 817B!GT3X 5.0 Mustangs 13 August 4th, 2008 09:55 PM
no start no crank no nothing cali 5.0 5.0 Mustangs 14 June 19th, 2007 01:13 PM
