Windstar problem.
Old June 21st, 2011, 04:28 AM   #1
2001 mustang v6
StubzStang is on a distinguished road
Arrow
Windstar problem.
Hey guys I need some help. I ran into a few problems with my windstar install. I got the full kit from vap. Everything with the install was smooth until I started the car and took it for a drive around the block. Here are the problems:
1. Coolant started leaking by the top of the overflow tube. During install, I ended up losing the overflow bolt and replacing it with a new one, could this be causing my leak prob?
2. There's a vacuum leak right behind the TB. I kept the old intake gasket on with the new ones on the windstar.
3. After doing a test drive around the block I noticed a check engine light when I parked in my driveway. I can't remember the code but it had to do with the cylinder head being to hot
I feel like I messed up somewhere. Any help and/or suggestions are appreciated.
'01 3.8L
Old June 21st, 2011, 08:55 AM   #2
Six Banger's Avatar
2001 - 3.8
Six Banger has a spectacular aura aboutSix Banger has a spectacular aura aboutSix Banger has a spectacular aura about
Don't use 2 gaskets on your TB.
Check your MAF + connector too, if its not plugged in you can throw that code, it happened to me when a mechanic forgot to re-connect it after fixing my A/C. Take your battery off for 20 mins after you check it. Putting some electrical grease on the connector wont hurt either.
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome.
Old June 21st, 2011, 11:24 AM   #3
Formerly 01silversixer
SlowSix's Avatar
2001 V6
15.47@89.57
SlowSix has a spectacular aura aboutSlowSix has a spectacular aura aboutSlowSix has a spectacular aura about
If you're losing coolant it might throw the cylinder head too hot code.
And I had to get gasket paper and make my own gaskets for the TB. None of the store bought ones worked and I had a vacuum leak.
Build Thread
Old June 21st, 2011, 02:10 PM   #4
2001 mustang v6
Maf is plugged in.
Ok, I'll try removing one of the TB gaskets (2 came with my kit).
Im going to try topping off the coolant today. I heard that some times the overflow tube cracks when bending it. I hope its not that.
Thanks guys
'01 3.8L
Old June 21st, 2011, 02:17 PM   #5
SlowSix's Avatar
2001 V6
15.47@89.57
The way the gaskets on the TB should go is
Windstar > Gasket > Angled TB Spacer > Gasket > TB
I had to make my own like I said.
Build Thread
Old June 21st, 2011, 03:39 PM   #6
Jetflo's Avatar
2001 3.8L w/ 5spd
Jetflo will become famous soon enough
The bolt for the coolant overflow pipe is national pipe thread (npt). You can get npt fittings at the plumbing section of most hardware stores. I believe the plug you need is 1/4" npt (even though it looks way better than 1/4" in diameter).
If you cut a bit too low, then you will need teflon tape (plumber's pipe sealing tape) or gasket sealant to stop the leaking. Teflon tape did the trick for me.
You can try using the Windstar throttle body gasket instead of the Mustang paper one. The Windstar gasket is a like a rubber O-ring with a rectangular loop too. You'll just need to snip off the rectangular portion to make it work with the VAP kit.
The check engine light could be due to your vacuum leak. You'll need to get the codes to see for sure.
Are you absolutely certain you're not pregnant?
Old June 21st, 2011, 07:49 PM   #7
2001 mustang v6
I had them set up like this rEmoved 1 and it got worse. putting it back tomorrow.
The damn vacuum port for the iac also came off, what's the best way to fix this? I left my old lower to upper intake gasket on, is that bad?
I also found my coolant leak. It was coming from the new bolt, I used Teflon tape and gasket sealer and thAt should solve that prob. Thanks 4 the advice.
Now it's just the vacuum leak bothering me, I think it could be a few things: the iac port that came off, TB gasket not working, or if that old gasket that I left on is the prob..Working on this tomorrow any thing else I should check out?
'01 3.8L
Old June 22nd, 2011, 12:55 AM   #8
SlowSix's Avatar
2001 V6
15.47@89.57
You need to take the old lower to up gasket off. The Windstar has rubber o ring type gaskets that seal it up. As far as the TB leak, I recommend just getting some gasket paper and an exacto knife and making your gasket. Use the TB spacer as the template.
Worked for me.
Build Thread
Threads Similar to: Windstar problem.
New Windstar Parts from VAP. IF YOU OWN A WINDSTAR MUST SEE* mustangmike! V6 Mustangs 17 May 24th, 2011 05:36 PM
VAP windstar kit vs junkyard windstar intake Lumoon V6 Mustangs 6 April 30th, 2011 02:18 PM
Windstar/EGR problem 04mustang232 V6 Mustangs 0 March 8th, 2010 05:59 PM
Windstar? Stang808 V6 Mustangs 5 February 15th, 2010 03:09 PM
windstar over cai? BostonPerformance V6 Mustangs 25 June 17th, 2008 07:12 PM
