SERVICE ENGINE SOON LIGHT
HI IM NEW HERE AND THIS IS MY FIRST TOPIC SO IT WOULD BE VERY HELPFUL IF SOMEONE COULD HELP ME OUT...MY SERVICE ENGINE SOON LIGHT TURNED ON SO I CHECKED THE TROUBLE CODES AND MY 5TH CYLINDER WAS MSFIRING SO I CHANGED THE SPARK PLUG AND THAT SEEMED TO SOLVE PROBLEM BUT NOW MY SERVICE ENGINE SOON LIGHT WONT TURN OFF ...I TRIED DISCONNECTING THE BATTERY TO SEE IF THAT WOULD WORK BUT IT DIDNT SO ANY OTHER TIPS??
1999 Ford Mustang V6
you might be throwing a new code, get it rescanned to be sure!
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
14.79 @ 92.15
If you are not throwing a new code, check the Ford DTC and recalls for your car, because a computer programming code error by ford has been known to trigger the P0300-P0308 codes for misfires on their vehicles under false pretenses. If it is the same code and you have replaced spark plug/wire and you have no pressure loss of cylinder leak, it could just be that the computer has a messed up tune. It could aslo be as serious as a head gasket leak if your block is leaking and running weak.
HEY THANX FOR ALL THE HELP ...THE CHECK ENGINE LIGHT TURNED OFF THIS MORNING AND RESCANNED IT JUST TO MAKE SURE AND ITS GONE SO THE PROBLEM IS FIXED I GUESS IT WAS JUST A MATTER OF TIME ...I WAS JUST WORRIED CUZ I JUST HAD THAT ENGINE SWAPPED IN SO I THOUGHT IT MIGHT HAD BEEN THE NEW ENGINE BUT THANX FOR ALL THE HELP
I ALSO HAD A SEVICE ENGINE LIGHT AND THE CODE WAS D262 WTF IS Missing SCP message?? CAN SOME1 TELL PLZZZ
Threads Similar to: SERVICE ENGINE SOON LIGHT
| the dreaded service engine soon light | dark-samurai2 | V6 Mustangs | 28 | August 1st, 2007 09:01 PM |
| Service engine light wont go away!!!! | dgt_mustang | V6 Mustangs | 59 | July 10th, 2007 07:43 PM |
| Dam Service Engine LIght on AGAIN!!! | jrfan4life | 99-04 | 31 | March 30th, 2007 11:11 PM |
| Service engine soon light blinking..... | jrfan4life | 99-04 | 26 | March 20th, 2007 11:18 AM |
| Help Me (Service Engine Light) | sgrcltpunk | 99-04 | 3 | March 10th, 2007 01:57 AM |
