02 Mustang V6
13.605 @ 101.60
![]() iTrader: 6 reviews
IAC Adjustments
Does anyone know the type of tool you use to adjust the IAC spring tension? It looks like an allen key but only 5 sided...
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
#2 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
Re: IAC Adjustments
02 Mustang V6
13.605 @ 101.60
I thought so too, a Torx, but I tried several and they wouldn't work. It honestly looks like a pentagon. Going to take a picture.... N/M My camera sucks...
#4 | |
02 Mustang V6
13.605 @ 101.60
Cleaned out but engine still rev's down really slow, likes to stay in the 1500 range but takes like 4 seconds to get down to that from 3k... not in neutral, engine acts beautiful in neutral. Put it in first gear, take off, hit 3k, push clutch in, hangs at 3k for 3/4 sec, then OH SO SLOWLY down to 1500... sometimes it'll go down to 900 or sometimes hang at 1500. I took it off and adjusted it w/ pliers and it helped a bit but I don't wanna waste the time to keep doing that... I just wanna turn the screw, the 5 sided funky screw that I don't have a driver for...
#6 | |
thats strange I had the same problem but it wentaway when I cleaned my t.b
#7 | |
just in case have u done something to your car like a tune or something?
02 Mustang V6
13.605 @ 101.60
No but soon I'll be getting a tuner, hopefully to try to solve the issue as well as HP gains if the IAC isn't doing it.
#9 | |
The slow rev down is there by design. It's part of the OEM tune that is there to help emissions. Annoying as hell, yes. But it's there for a reason. If you get a tuner or chip, you can ask the provider if they can take the slow rev down out of the tune.
2002 Summer Beater |
02 Mustang V6
13.605 @ 101.60
Well that's good to hear because it frequently hangs on 1500 RPMs and will not come down ever until the next time I take off or something, sometimes it even hangs at like 3000 for 3-4 seconds (Which seems like forever) before it slowly backs down then hangs at 1500 permanently. Went through 3 TPS, All kinds of idle settings, cleaned the IAC, I'm out of ideas...
Threads Similar to: IAC Adjustments
| 1999 headlamp adjustments | mwturner | Visual | 4 | August 26th, 2007 03:42 PM |
| headlight adjustments | xiiiix | Visual | 4 | June 26th, 2007 08:03 AM |
| hood adjustments | 95kystang | Visual | 1 | June 23rd, 2007 05:16 PM |
| adjustments | DragonFreak | 96-98 | 1 | May 20th, 2007 05:19 PM |
| stock valve adjustments 89gt | cali 5.0 | 5.0 Mustangs | 0 | June 25th, 2006 01:48 PM |
