2004 V6 Mustang
Too good to be true?
Hey guys, I was looking into f/i for my sixer and my mechanic friend is going to sell me this kit he has that supposedly fits the 04 stangs for $500, which sounds insanely cheap if everything checks out...he gave me this info about it, is this complete or am i missing something?
(1) Hybrid Turbo Charger: .57 compressor wheel trim mapped for low and high boost setups Oil fitting gaskets & mounting studs included Capable of producing over 450 horsepower Wet float bearings & properly balanced 3" inlet diameter with a 2" outlet 50 A/R compressor housing .63 A/R turbine housing 1/8 NPT oil inlet T3/T4 hybrid (1) Front Mount Intercooler: Large design cools down the turbocharged air efficiently Strong TIG welds will support high PSI levels Lightweight aluminum racing intercooler Extra thick core provides ample cooling 2.5" cold outlet & 2.5" hot inlet Less then 2% pressure drop (1) Universal Intercooler Piping Kit: Lightweight yet strong aluminum piping May necessitate light modification to fit (16) stainless steel worm gear clamps (2) 2.5” 90 degree silicone couplers (6) 2.5” straight silicone couplers (2) 90 degree 2.5” bends (2) 60 degree 2.5” bends (2) 45 degree 2.5” bends (2) straight 2.5” pipes (1) Boost Controller: Can be setup to adjust boost PSI on the fly Can be adjusted for any PSI level desired Control your boost with a precise click Includes complete install kit Anodized aluminum finish CNC machined design (1) Slim Cooling Fan: Fan can be used to cool: A/C condenser, oil or transmission cooler, mounting on an intercooler to prevent heat soak, or cooling a a2w radiator Slim design provides excellent engine bay clearance Includes the mounting tabs for a easy zip tie install Reversible design can either pull or push air Versatility of a push/pull reversible fan Superior flow of a curved-blade design Creates additional aftermarket cooling 1.25" thick outside perimeter 2.50" thick inside perimeter (1) Electronic Turbo Timer: Ensures a proper cool down for your turbocharged car every time Includes pigtail wiring and extra wiring for ease of installation Important to preventing premature turbo wear and failure Mounted inside the vehicle for on the fly adjustments Precisely calculates the cool down period for the motor Auto mode feature creates a hassle-free operation Increases turbocharger's operating lifespan Bright Easy to read LED Digital Display Failure to reduce the temperature of the turbo could result in "coking" of oil inside the turbo Coking is the baking of oil, turning it into a grimy substance (1) 10 Meters Heat Wrap: Heat powers the turbochargers turbine inlet. Keep the heat inside the exhaust pipes Heat kills the turbochargers compressor inlet. Keep the heat out of the cold piping. Control additional engine bay heat and prevent overheating. Keep intercooled air cooled. Made of very high temp fiberglass. (1) High Flow Intake Filter: Protect the turbo system from debris Instant HP adder Extreme high flow 3" inlet perfectly matching the turbocharger inlet (1) High Flow Breather Cap: Extreme high flow Keeps crankcase ventilation clean for emissions Works in conjunction with the catch can to keep inside of turbo piping oil free (1) Coolant Sensor Bung Monitor the water temperature via this sensor relocation Easy solution to run aftermarket coolant sensor Provides more precise readings then the stock location Features 2 installation clamps for an easy add on 38mm ends fits most OEM coolant hoses Strong Aluminum construction (1) Non-divided T3 Flange Water jet cut for precision flow Mild steel for easy welding to an adapter pipe or direct to stock manifold |
Ok, I didn't read everything in detail...but no it is NOT complete.
You would be missing several things: Turbo headers, custom routed piping, wastegate, BOV, gauges, MAF, Injectors, Fuel pump, and probably some more small stuff. However, for everything you would be getting for $500...yes I still think its a good deal
![]() Pretty.............................Slow Mods: Apparently more than 250 characters |
Formerly 01silversixer
2001 V6
15.47@89.57
That list looks like the list that is on ebay junk turbo kits.
I would pass on it. |
2004 V6 Mustang
Yeah i knew about the injectors, fuel lines, and MAF, but thanks for the other details i was forgetting.
And to silver sixer, thats probably where he got it from, cuz i looked on ebay and found the exact same list -.-, well at least i know one of my friends isnt mechanically inclined. Any idea if TMA is coming back, i thought he was supposed to a bit ago and I've heard he's a guy who you can trust with that. |
14.37 @ 96
PM'd
Threads Similar to: Too good to be true?
| Too Good To be True? | carney | The Clubhouse | 9 | March 10th, 2011 10:48 PM |
| Too good to be true, right? | v6mustang05 | V6 Mustangs | 39 | October 10th, 2010 06:06 PM |
| Way To Good To Be True!!! | Aceswild 02 | 99-04 | 21 | July 15th, 2010 03:17 PM |
| To good to be true?? | 87FloridaGT | The Clubhouse | 16 | March 3rd, 2009 11:10 PM |
| to good to be true? | thorpedo26 | The Clubhouse | 13 | November 25th, 2008 07:10 PM |
