'98 Mustang
Something is Draining Battery??
Notice today the gauge on amp output was on "O".I turn the a/c and Radio off and it goes p to "R"??
Any ideas?? The battery is 3 years old. Thanks. 98Mustangfla |
Tree Fiddy Z
Sounds maybe like an alternator problem. Your car starts okay despite these problems? Try being more specific
'98 Mustang
Check Engine LIght on...
Had all the brakes repalced and one rotor. Possibility this would trigger the check engine light?? I checked all fluids..OK
Temp gauge and oil pressure gauge fine. Any ideas?/ I did notice the battery is jumping from "R" to "O". It is 3 years old. Would the light come on for low battery?? Thanks. 98mustangfla |
Tree Fiddy Z
Take it to advance auto and they can do a battery or alternator check
#5 | |
Tree Fiddy Z
Re: Check Engine LIght on...
and no brake maintenance has nothing 2 do with check engine light |
Zoolander
04 Cobra #2260/3768 1/820
sounds like your car is undercharging. Go with what breakout said. Have them check your alternator, and the cables, if those check out alright have them do a test on your battery.
'98 Mustang
I screwed with the reply.
Yes, it starts up no probelm. Would the check engine light come on for that?? Any ideas on cost to take care?? Thanks man. |
#8 | |
u can check the alternator your self by starting the car and then disconecting the negative battery cable the car is supposed to not turn off... if nothing happened go to a shop and get your alternator check and every other electric things like cables and all(it can be somethng loose)
Tree Fiddy Z
probably not
Zoolander
the cel usually won't come on for undercharging. The cel could be for a number of things. Best bet bring it to a place like advanced auto parts that does free obd II readings.
#11 | |
Tree Fiddy Z
#12 | |
I've always did that and never had a problem but just in case I will never do it then cause Idk it would do mayor damage....
Tree Fiddy Z
no major damage. I was told to do it by a friend of a friend in high school on my old car, and what juice was left in the alternator fried and i couldnt make it to advance auto and had to pay 4 a tow
#14 | |
ohh that could be bad luck caue never happened to me :p and I have done it on my stang a 240sx an old accord.... i think it may depend on the alternator problem( I mean what part of the altrnator is fucked)
#15 | |
[8MINUS2]
- anyway in all my infinite wisdom I'm gonna say your alt is going bye bye
Your alternator will not throw a light until the amperage output drops below 3.5amps thats the bare minimum to keep the car running and keep your battery from going flat. i know this because i just did my alternator this morning it was putting out a measly .5 amps at 2k rpm so it was fucked. you can test the alternator your self and all the corresponding circuits very easily in under 15 min with a volt meter. and of course the directions for the pinpoint test. i used the ford TSB and service manual cd i downloaded i tell yah the thing is as good as gold and 10x better then a Haynes manual. on a positive note my head lights dont dime when my stereo and blower motor are both on any more
and a new heavy duty alternator set me back 280 bux with a 2 year warranty. watch out for the top mounting both tho mine was stuck and i snapped the bitch off luckily it was easily removed with my figures after i got the alternator off.
#17 | ||
Threads Similar to: Something is Draining Battery??
| draining the tranny fluid | JASonic | V6 Mustangs | 3 | October 13th, 2007 12:49 AM |
| Draining Coolant | jbm5781 | 96-98 | 5 | August 18th, 2007 02:35 PM |
| battery relocation with second battery | onewinner | 5.0 Mustangs | 1 | May 30th, 2007 11:30 AM |
| Draining coolant... | 96_gt_stanger | 96-98 | 4 | October 19th, 2006 09:02 PM |
| Cleaned Engine - Draining Battery Now When Off | Convertible 5.0 | 94-95 | 20 | September 27th, 2006 09:30 AM |
