2001 mustang v6
Slow/weak start
Hey guys my car has been starting really slow and weak lately. It turns over slow and takes about 10-20sec before it starts.
I've checked the battery( optima red top 1yr old) it reads 12.6 volts and the charging system seems to working according to the gauge on the dash. I also changed the fuel filter and can hear the pump when I turn the key. The car starts up a little bit better if was just driven but if I park for like an hour I get that really weak start again. What could this be? Starter maybe? The battery has also died a few times. How else / what else could I trouble shoot?
'01 3.8L |
#2 | |
2001 3.8L w/ 5spd
The result is that the battery holds less charge and discharges with less current and at a lower voltage. It is certainly possible the cause here is a bad battery. If you can, take the battery to an autoparts store and have them test it.
Are you absolutely certain you're not pregnant?
2001 mustang v6
Will bring it in tomorrow. Didn't know the battery could keep working even though it's bad. Thanks
'01 3.8L |
2000 Mustang 3.8
ehh w/e the mostly stock time is
when was the last time you changed your plugs? any other symptoms? bad mpg? electronics lights dimming? or just doesn't want to start?
2001 mustang v6
Changed the plugs last year, also have msd wires. Mpg seems normal. The headlights do dim when it's turning over, but it starts. It's not started only like twice but started up on the second try.
'01 3.8L |
2000 Mustang 3.8
mine started to do that before the alternator went bad. took my battery with it. my want to go and have your alternator checked.
2001 mustang v6
I'll bring it in with the battery
'01 3.8L |
#8 | |
Better than ONLYaUNCfan's
2012@lightspeed
Formerly, AhobosCheese and Cheddars.
2001 mustang v6
Well after a night of sitting I hit the battery with a voltmeter and it read about 11.4
Upon cranking the engine the volts dropped down into the 9's. With the engine running it went back up to 14+ volts. When I turned off the car the volts began dropping back to 11. I'm pretty sure it's the battery, what do you guys think?
'01 3.8L |
1988 mustang 5.0
I'm a battery specialist and yes the battery is bad always remember Any thing under 12 volts is bad right off the top. There are 6 plates in a battery or 6 cylinders on a gel cell and each plate/cylinder is 2 volts actually 2.04-2.06 volts x2 is 12+ volts. When u charge a battery remember you are charging cranking amps NOT volts you can never put volts back in a battery only cranking amps. SECOND the reason it went to 14 volts when running is because when u test a battery when motor running it is not testing battery it is actually testin alternator that's why with a volt meter it will jump up as soon as u touch power and ground should read same at alternator and battery when running . Change that battery it is bad.
#11 | |
2001 mustang v6
'01 3.8L |
Threads Similar to: Slow/weak start
| Another weak 2v dyno | GTGUY | 99-04 | 16 | June 9th, 2011 01:43 PM |
| car starts slow.. not slow but | 1BADSTANG | V6 Mustangs | 14 | March 31st, 2008 08:16 PM |
| im weak lol | Hourofpain | The Clubhouse | 10 | October 13th, 2007 09:23 PM |
| weak T5? | radster87 | 5.0 Mustangs | 5 | July 17th, 2007 01:25 AM |
| slow start-up | shadow98gt | Modular Mustangs | 3 | April 28th, 2007 03:17 PM |
