Need some Cam tech
Old June 23rd, 2011, 09:06 PM   #1
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Need some Cam tech
When setting up the valvetrain you bring the each cylinder to top dead center, tq rocker hold down bolt to 22-29ftlbs and turn the hold down 1/4 turn to set preload correct?
How do you set the cps with an alignment tool?
Went throught the steps swaping my current cam with a bigger one and having issues here. I'm thinking my problemb is either a vaccuum leak or the timing is off. It will turn over and fire but shuts off right after. When it does shut off I hear the compression leak out slowlly but cant make it to the engine to see where it's coming from.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old June 23rd, 2011, 09:10 PM   #2
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
it sounds like the timing is off, you have a stuck lifter, or maybe a loose spark plug?
Old June 25th, 2011, 03:03 PM   #3
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
Oh shit, I guess the iac has to be plugged in
And the hissing when the motor turned off was from where I did not put the t stat on( incase for some reason I had to tear back into it I left everything off)
Old June 25th, 2011, 06:24 PM   #4
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
oh dear lol
I just put my cps back in the way it came out :p
If you put #1 in perfect TDC, it lines up just fine. You put it in turned just a little bit, that way it follow the curve of the teeth on the gears and will line up.
My UDP HB has a mark on it and I got my head between it and the radiator and spotted it. Lined it up directly with the TDC mark on the engine block.
Previously, knowing Id have to do that, I checked to make sure then lined up they were corretly placed in TDC ( this was with the heads off and T/C off to see alignment of cam and crank sprockets.
My stock HB didn't have a mark, so you may need to take your timing cover off to find "Perfect" TDC.
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Threads Similar to: Need some Cam tech
tech? about sc i just got. psycho bob 2005 - 2010 56 July 11th, 2010 03:59 PM
yes tech i know 707Stang The Clubhouse 13 October 4th, 2009 10:35 AM
looking for tech help!!!!! downshift83 V6 Mustangs 3 May 20th, 2009 06:47 AM
Help Please!!! I need tech help. kevnsue 5.0 Mustangs 4 September 22nd, 2008 12:46 PM
