Wiring Diagram
Old May 13th, 2007, 01:05 AM   #1
marknlori's Avatar
marknlori is on a distinguished road
Wiring Diagram
I need some tech advice for once on the 3.8
I bought a Sunpro 5" tach and was reading the instructions today and ran into a small problem.
Does anyone know a good working URL for the wiring diagram for the 3.8 so I can follow these instructions, or know the solution that can post it for me??
"DISTRIBUTORLESS IGNITION SYSTEM EQUIPPED ENGINES
Connection of the GREEN (tach signal) wire to the ignition is
specific to the engine and ignition system. See wiring diagrams
in your vehicle service manual."
Thanks in advance,
Mark
Old March 3rd, 2010, 05:31 PM   #2
Nick_Adam is on a distinguished road
If you pull out your gagues and look at the pig tail in the back y9ou should see a Dark green and yellow wire that is the inut for your tach here is the diagram if you need anything else or more help Pm me
http://www.veryuseful.com/mustang/te...nt-Cluster.gif
Old March 3rd, 2010, 05:39 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
do not go by the above link... that is for an 89-93 fox body. It will not work on your application. here is walk through to grab the tach signal
How To Install a Raptor Shift Light on your Mustang
BUILD 2 IN PROGRESS
Old March 3rd, 2010, 05:53 PM   #4
oww my bad I messed up but still that is how you would find your led and that other link is a nice write up
Threads Similar to: Wiring Diagram
wiring diagram. HMUSN All Other Vehicles 2 September 23rd, 2007 10:37 PM
wiring diagram for stereo exofreeze Audio/Video 7 July 25th, 2007 09:57 PM
MACH 460 Wiring Harness Diagram 1wicked281 Modular Mustangs 2 May 24th, 2007 07:48 AM
wiring diagram scubasteve041186 Audio/Video 8 March 31st, 2007 12:07 AM
Wiring Diagram slingblade05 5.0 Mustangs 3 October 16th, 2006 05:53 PM
