LinkBack (2) | Thread Tools |
#1
'03 V6
Loose clutch pedal?
I have had a progressive issue with what I 'think' is a loose clutch pedal. It seams that at lower rpm 1300-2000 range, especially under braking or as I am slowing in neutral that the clutch pedal seems to vibrate or at times i can actually look down and see movement in the pedal. Does it just need to be tightened or is this a clutch cable issue? any opinions or instructions would be greatly appreciated.
BLACK 6er CLUB |
Dancing Naked In The Rain
If you've got the windows down can you hear a squealing or squeaking noise? When my TOB starting going out, my clutch pedal vibrated quite a bit.
And my feet are very ticklish so it was a bit difficult to drive
2000 Mustang 3.8
ehh w/e the mostly stock time is
2000 mustang v6
14.6@99.68
Ok so answer me this...I start my car there's a small faint but noticeable sqeak coming from the car but when I rest my foot on the clutch as in just press it down mabey 1/2 inch or just enought for the pedal to move it goes away....loose clutch cable?? Or wat how do I fix??
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust Fixed clutch!!!!! "My mustang likes a good ol' fashion bowl of rice....especially fried" |
2000 Mustang 3.8
sounds like your TOB is going out, mine does that all the time.
#6 | |
'03 V6
So i guess another question is how much 'play' should be in the pedal, like how much should i depress the pedal before you start hitting tension so actually engage the clutch?
BLACK 6er CLUB |
SG
2005 Mustang GT
2001 Mustang V6
I also have the damn vibrating clutch problem. Going on my Third TOB now >.<
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok. 05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel |
#9 | |
What kind of TOB are you using? Ford OEM works best.
SG
2005 Mustang GT
2001 Mustang V6
My stock one went out, then I made the huge mistake of getting a Duralast cause I was in dire need of a clutch kit. So that is the one that is going out atm. I remember you telling me before to get the Ford OEM one, so when I get around to changing it out i'll replace it with that.
Good stuff, man. I know there's a website that sells it, I just can't remember the site (most only carry the V8 TOB). I think Mr Red Pony might have the link.
SG
2005 Mustang GT
2001 Mustang V6
Awesome i'll check it out. Thanks dude.
Mine did this a few years back, i installed a Steeda clutch assembly. The clutch, which probably had a bad TOB at the time, lasted a few more years till i had to replace that. The clutch pedal adjust for the cheap plastic clutch quadrant that ford gives wears works fine until it starts to bend and warp. The metal one from steeda allows for you to adjust the height for clutch engagement, and the pedal shouldn't vibrate.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/223662-loose-clutch-pedal.html
| Thread Loose clutch pedal ie. no resistance | MX-5 Miata Forum | BoardReader | This thread | Refback | March 10th, 2012 11:10 AM | |
| Thread noisy, clicking clutch pedal | Forums at Modded Mustangs | BoardReader | This thread | Refback | September 5th, 2011 06:21 PM | |
Threads Similar to: Loose clutch pedal?
| clutch pedal loose? | Ochoa | 99-04 | 5 | September 11th, 2010 09:50 AM |
| clutch pedal vibration and excessive clutch chatter | mscribellito | 99-04 | 13 | August 19th, 2010 04:59 PM |
| Can't tell if its my TOB or just a loose clutch cable | mustangmanic | 99-04 | 14 | July 28th, 2009 10:32 PM |
| Just had tranny work, clutch loose for a little while? | fdjizm | 2005 - 2010 | 8 | September 3rd, 2008 09:54 PM |
| Gas pedal loose | new 5.0 | 94-95 | 3 | January 24th, 2007 12:48 PM |
