2000 m112'd 3.8
loss of power need help asap
so all of a sudden my car stalled and now it bogs and wont rev up no matter how I am on the gas and than it all of a sudden shoots up. Also when im coasting at a steady rpm it surges alot. I went and changed the plugs wires and fuel filter cleaned the iac and tb reset the ecu and still not fixed what could it be
broken maf sensor...my f150 did the same thing when my maf's wire got broken....replaced it and problem solved
pull your maf and look at it |
2000 m112'd 3.8
well lucky me I have my maf from my old car I guess its worth a try ill have to wake up extra early for work tomorrow
then that will be an easy way to see if thats the issue...lets hope
2000 m112'd 3.8
but how could the wires just get messed up?also my ac went out as soon as I put on my lts turns out on the pass side it sat against the ac line and put a hole in it and leaked out all the freon
2000 m112'd 3.8
swapped the maf and the problem is still there im beginning to think that my pretty much brand new screamin demon went but I cant find my stocker!
04 Stang 1.0Gallon V6
14.45 @95.8
![]() ![]() iTrader: 2 reviews
what did you gap the plugs to?
2004 Bolt on & Cammed 3.9L V6 |
2000 m112'd 3.8
like .56
i've heard very bad things about that demon coil pack....
2000 m112'd 3.8
ughhh I need to find my stock one what are the symptoms of a bad coil or anyway to test it
1996 V6
When my coil went, my car would drop to low rpms and just die. after that, it would crank, but wouldn't start. if I waited a day or so, it would start fine, but do the same thing after 15 minutes of driving. I didn't have any problems with blogging, but that may be because it just died before it got the chance. lol
2000 Mustang 3.8
ehh w/e the mostly stock time is
my car's coil went out and it would lose a lot of power and the idle would sound really deep and you could tell that it was missing. also some fuel came out of my tail pipes. but try the old coil, i have heard a lot of bad things about the screamin demon coil packs on our cars. get the stock one back on asap. i replaced my coil with an oem one.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
2000 m112'd 3.8
changed fuel filter plugs wires coil back to stock cleaned iac reset ecu and still didnt fix it. pulled the cel and its a rich bank 2 so once the weather cools down today im going to check the o2 sensor and wires on that side I bought a new sensor also im guessing bank 2 is the pass side?
2000 m112'd 3.8
problem solved was the o2 sensor
Threads Similar to: loss of power need help asap
| Loss of power top end? | Stangman50 | 5.0 Mustangs | 5 | February 6th, 2010 08:16 AM |
| power loss | 03Gtmustang | 99-04 | 13 | September 6th, 2008 12:16 AM |
| Loss Of Power! Help Please! | alamo11 | V6 Mustangs | 8 | December 14th, 2007 08:34 AM |
| power loss? | xedubx | 99-04 | 16 | June 20th, 2007 09:52 PM |
| Loss of low end power | ByPopularDemand | V6 Mustangs | 24 | May 10th, 2007 09:00 PM |
