Skar Gone
1998 Mustang V6
17.27@76.66
Underdrive pulley?
I know this has probably been brought up 100 thousand times by Unknowing noobies like me, But...
What, And How does an underdrive pulley add Power? ![]() Also, Here's a sound clip. "Click Me."
how do they work you ask....well basically they free up hp caused by parasitic drag...granted its not a lot of hp in our cars (i think a full set of UDP net you around 8-10hp)
as for the sound clip...i guessed right the other day...sounds like someone just cut the cats off the factory exhaust...time for a custom setup XD |
Skar Gone
1998 Mustang V6
17.27@76.66
I crawled under it, It has all 4 Cats still, Unless they've Gutted them out?
well their either gutted or the mufflers been removed...somethings missing that should be there because it's to high pitched right now for having it all. didn't you say something was taken out and looked like tubing was welded in on your exhuast? i know it still has the single tip
Skar Gone
1998 Mustang V6
17.27@76.66
Well it looks like someone has put a new muffler, its Rusted still, But looks differant than Im used to seeing, its shorter
MM's king of Neon's
404 - car not found
17.81@87
8-10hp sounds pretty generous, unless they're very extreme UDP's, but I could be wrong. I just take a lot of those hp claims with a grain of salt, like the CAI's that claim to give you 20hp.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
#8 | |
remember i said full UDP set...not just a single pulley. that's where alot people get confused |
#9 | |
MM's king of Neon's
404 - car not found
17.81@87
#10 | |
#11 | |
MM's king of Neon's
404 - car not found
17.81@87
There always seems to be a factory freak though.
2000 Mustang 3.8
ehh w/e the mostly stock time is
do UDP have nay draw backs? also since yall get cheap runs, someone should put there A/C on to see just how much hp it saps from the motor.
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
Better than ONLYaUNCfan's
2012@lightspeed
cant run a system
Formerly, AhobosCheese and Cheddars.
2000 Mustang 3.8
so if i plan on getting a sub and an amp i shouldn't get UDP?
2000 Mustang 3.8
probably just a bigger alternator, like a 200 amp or something.
MM's king of Neon's
404 - car not found
17.81@87
Bigger alternator is better than an overdrive pulley. Lots of Cobra guys run into this problem when they try to up the boost on their blower, and inadvertantly spin the shit out of their alternator and burn it out. Think about your alternator like a blower, and amps like boost. Sure you could run a smaller pulley and get more, but you're more likely to destroy something than if you just get a larger blower/alternator with a regular pulley.
#20 | |
2000 Mustang 3.8
Threads Similar to: Underdrive pulley?
| Underdrive pulley | 00quicksilver | 2.3 Mustangs | 1 | April 24th, 2011 01:21 AM |
| Underdrive Pulley? | Rob2002GT | 99-04 | 16 | March 22nd, 2010 08:03 PM |
| Does this look like a race underdrive crank pulley & stock water pump pulley? | STREETFIGHTER50 | 5.0 Mustangs | 8 | January 26th, 2010 10:47 AM |
| ASP underdrive pulley | supercharged421 | V6 Mustangs | 10 | February 19th, 2008 08:58 PM |
| underdrive pulley | Baker02125 | V6 Mustangs | 23 | December 25th, 2007 01:20 AM |
