Alternator/ electrical issues
Old July 8th, 2011, 05:53 PM   #1
always wanted a pony's Avatar
2003 Mustang
always wanted a pony is on a distinguished road
Last year I replaced the alternator and the battery after confirming that the alternator was in fact bad.
Last week my car wouldn't start and after jumping it I had no power to the radio, the instrument cluster or anything else. I parked the car and killed the power, and it wouldn't turn back on until I jumped it. After I jumped it it ran and drove fine until today.
Today it barely started and the battery gauge was jumping around. I checked the battery and it was fine, but the alternator was at 12.7. I checked it again a few minutes ago and the alternator was back up to 13.7.....what gives? What should I check?
Old July 8th, 2011, 07:08 PM   #2
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
sounds like you got the wrong pulley on your alternator. where ever you got it from go tell them that they gave you a bad alternator and get a new one, and make sure that you take your old one aswell so you can compare them and make sure that you are getting the correct one. but i am only guessing that you got the wrong pulley on your alternator, compare it to ur old one and see if they are the same.
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old July 8th, 2011, 11:50 PM   #3
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
RedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really nice
Was it a Duralast from Auto Zone?
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok.
05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel
Old July 9th, 2011, 06:30 PM   #4
2003 Mustang
it's from oriellys, remanufactured.
Old July 9th, 2011, 10:25 PM   #5
Resident badass
Mr. Red Pony's Avatar
01 Built V6 (3.9)
13.91 @ 99.1 N/A
iTrader: 10 reviews
Voltage regulator is shot.
Meaning. Get a FoMoCo new Alt.
271rwhp N/A V6
Suck it.
Old July 10th, 2011, 09:02 AM   #6
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
I'd always go new for alternators... Advance gives lifetime replacement on theirs. But I'd have it tested by Advance or elsewhere (free). And they'll tell you for certain.
Old July 10th, 2011, 12:00 PM   #7
2000 v6 mustang
1slowv6 will become famous soon enough
dont get an alternator from a parts store like autozone, advance etc...
lifetime warranty or not how many times do you wanna replace the damn thing
get a NEW alternator not a reman and always go for one with more amperage output if possible. it wont hurt anything it can only help especially if your running a stereo system or anything of the sort.
it sounds like the alternator is bad and not charging the battery, remember the battery is only meant to START the car. not keep it running, if you were driving the car off the battery then that is why the radio etc wasnt working. and will also cause sulfation of the plates in the battery meaning its life has been reduced significantly.
BEFORE YOU DO ANYTHING check all connections and make sure they are tight
also feel your primary wire (aka battery cable) the wire that runs from the battery to the alt. if it is crunchy then u need a new cable.
you said you tested your battery and got a voltage reading?
if you have a volt meter or something then check for voltage drop in the wires becuase corrosion could cause the alternator to not be able to charge the battery when infact you have a perfectly fine alt.
If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
Old July 10th, 2011, 01:12 PM   #8
2003 Mustang
how can i check for a voltage drop in the wires?
Old July 10th, 2011, 03:16 PM   #9
2000 v6 mustang
put the leads of your voltmeter across the wires in parallel like. touch the positive of the battery to where it leads on the starter and disable your ignition. you get your reading while your cranking the car thats why u disable the ignition
the theory is that if there is too much resistance in the circuit the meter becomes "the path of least resistance" showing a voltage
an acceptable voltage would be .1 or less per wire
if you get good readings on that then at least u know ur cables are fine.
but like i said tighten all connections to be 100% certain that you dont have a loose connection in the circuit
if everything checks out and you continue to get a bad reading from the alternator then replace it
Old July 10th, 2011, 04:27 PM   #10
goren813's Avatar
'00 3.8L & '05 4.6L
Advance sells new ones. With a lifetime replacement.
Old July 11th, 2011, 12:53 PM   #11
2003 Mustang
ok, thanks guys! I tightened down all the connections and it seems to be fine now, I guess time will tell.
Threads Similar to: Alternator/ electrical issues
Electrical issues 84GT-306 5.0 Mustangs 0 April 11th, 2011 01:09 PM
Electrical Issues 96gtstang&V6 96-98 3 August 11th, 2010 02:46 PM
Electrical/Alternator issue? burner79 Audio/Video 2 April 27th, 2010 09:06 PM
Alternator and electrical Questions plz help starin 96-98 4 November 17th, 2009 07:20 PM
More Electrical Issues Megawatts88 V6 Mustangs 16 May 19th, 2009 09:08 PM
