Jailbait till 2013
2001 V6 / 94 Z28-gone
0-60 in -10.3
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Dome light/ Dummy light
1st time i've had to post something in here in a while! But here's the problem, so whenever you open your door, the dome light would usually come on, correct? Well, mine does not do that. No idea why. Secondly, my dummy alarm for when i leave my lights on doesn't come on either. (the light that goes off when you turn your car off and your lights are still on, and you open your door) Any ideas on wtf is up with it? Did a fuse blow or something? or is my car just messed up.
2003 V6 pony package
i would check the fuses.
2003 Pony Package 3.8L Mello-Tone XPS Exhaust - true duals 2.5" after cats to 3" tips Stock 17 inch chrome wheels. CAI,Tuned,tinted 35% |
1996 Mustang V6
Midway down the door in between the hinges there is a plunger/switch that should line up with a bracket on the door pillar. That is the door ajar switch, could be broken.
Jailbait till 2013
0-60 in -10.3
All fuses looked fine.. I'll add that my passenger side turns the dome light on, and my drivers side doesnt. and my light dummy alarm doesn't come on at any time. i think my car had a stroke
because only one side of it works.
Jailbait till 2013
0-60 in -10.3
nobody?
2000 Mustang 3.8
ehh w/e the mostly stock time is
I'm sorry to say this, but your car just had a stroke. I don't think that she will make it through next week
![]() Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK How to paint your rims: http://www.moddedmustangs.com/forums...ml#post3931042 |
Wyatt's #1 Slut
N/A
You are royally fucked.. Set fire to it
Jailbait till 2013
0-60 in -10.3
Then collect insurance money and buy a GT, right?
Wyatt's #1 Slut
N/A
Then finally be on my level
Jailbait till 2013
0-60 in -10.3
maybe i will just drop that 302 in there, then i'll have a cam and an intake already. But i don't want to deal with a headache.But seriously, no idea why it's not going off? The key alarm whenever i leave my keys in and open the door doesn't go off either.. |
2000 Mustang 3.8
probably the door ajar sensor thing.
Jailbait till 2013
0-60 in -10.3
But would that mess up the key and the light alarm things too though?
2000 Mustang 3.8
what do you mean key and light alarm?
Jailbait till 2013
0-60 in -10.3
like, when you open your door with your keys in it, it will set off an "alarm" or a ringing noise, same with if you have your lights on.
NEW PROBLEM HOLY GOD MY CAR DID HAVE A STROKE. So, i looked at all the fuses, but them back in, and then i had to jump my car because i left my lights on last night. and no my ABS light is on, and i can't turn traction control on! Dear god it's just a boat load of problems on my car happening today. |
2000 Mustang 3.8
maybe it actually did have a stroke... like half of the cars ecu is fried or something? or maybe a ground problem.
2001 Mustang V6
Its a V6
The driver's side door ajar switch is a common problem on all cars. Which door opens the most? The driver's door. Re place the switch its simple.
As for your ABS light check your ABS sensors.
Done so far: 3.73 w/ lsd rear end. custom 91 octane tune by R Style Performance rebuilt 4r70w 24% UDP pulleys aluminum drive shaft Windstar ready to be installed pending ported lower intake arrival |
1996 Mustang V6
#18 | |
Jailbait till 2013
0-60 in -10.3
Yeah, its the door ajar switch, mine made it so that it though my door was always open (think how annoying that got) I sprayed the switch and hinges with WD40 and it works fine. As for the ECU problems, double check all the fuses are completely in and in the right spot (and still good) since you checked them all. This time just pull the fuses that are related to the problem though. Have you tired taking the battery off the terminal for 20 mins and seeing if the problems re-set?
If not I'd imagine it has something to do with the jumpstart, my friends BMW fried some modules after he had to jump it.
Look on the bright side: If you're reading this, you're alive. And that's fucking awesome. ![]() |
Jailbait till 2013
0-60 in -10.3
Tried taking the door off, just for the hell of it, and can't get it back on
Kind of pissed at myself because i dented my fender in the process of closing my door when i got it back on. Now the door is back off and i'm waiting for help to get here to get it back on right.
Threads Similar to: Dome light/ Dummy light
| Dome light/ Licence plate light | sixstang | V6 Mustangs | 25 | May 23rd, 2011 10:11 AM |
| map light/dome light bulbs | 00gtv8 | Audio/Video | 4 | May 4th, 2008 10:30 PM |
| Red Dummy Light | lwhitetrash88l | V6 Mustangs | 11 | February 27th, 2008 09:56 PM |
| light bulb in dome light | myeleanor | 2005 - 2010 | 7 | August 31st, 2007 03:34 PM |
| How you can change your dome light color. (light on roof) | SonicStang | Visual | 25 | March 23rd, 2007 12:39 PM |
