Bad sound
Old July 9th, 2011, 05:54 PM   #1
adryan's Avatar
2003 Mustang V6 Pony Edit
adryan is on a distinguished road
Bad sound
OK... so I went out to get coffee this morning and I heard some intermitten knocking sounds that I've only heard for the first time. Went to get the oil changed and had my mechanic test drive her. He said it was just probably a loose heatshield or hanger. Went to the mall and stopped by my exhaust guy... we lifted the car and inspected and found nothing. He test drove it and didn't really hear it. So we popped the hood and and throttled it up and there it was. We looked for the location of the knocking and it seems to be comming from the upper rear passenger side of the engine compartment. He said it was internal and walked away.
I've been screwin' around on the road lately and I think something gave. The ticky-ticky-ticking sound happens when I release the throttle or when there is not a lot of strain on the engine but not all the time and usually on lower rpms. Any suggestions on where to start. My guess is something like rockers, lifters, valves, bearings and hoping not something else. I have no check engine light and have not lost any power or performance.
I'm taking her to my engine guy next weekend and see what he can do... but if anyone has had similar experience, please let me know.
thanks.
Adryan
p.s. will post video later
2003 Mustang V6 Pony Edition | 1968 Mustang RS |1980 Datsun 280 ZX | 1977 Camaro with '85 Intercooler Engine | 1971 Cadillac 472 cu.in. (7.7L) Engine | 1973 Mustang 5.0 Ragtop
Old July 9th, 2011, 06:02 PM   #2
Dancing Naked In The Rain
mcqueen's Avatar
You're 100% sure it's coming from inside the engine and not the passenger exhaust manifold? That manifold is known for cracking since the AC drips on it a lot and an exhaust leak will more than likely sound like a ticking noise. If it's not the exhaust, I'd put my money on a lifter or valve.
My Hubpages
Hey.. r u really a tranny??
Old July 9th, 2011, 06:05 PM   #3
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
sticky lifter?
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Old July 9th, 2011, 06:12 PM   #4
adryan's Avatar
I'm quite sure about the manifold. I have a leak on the driver side when the engine is cold and disappears in a few seconds when the engine heats up. Sound is more metallic. Do you have any idea on the costs for a mechanic to change it? Or, is this something that I can diagnose and replace in the garage with basic tools.
A
Old July 9th, 2011, 11:27 PM   #5
ag11hockey's Avatar
1999 Mustang V6
ag11hockey is on a distinguished road
i think we have the same problem. you hear it at idle and anywhere upwards of about 2k rpms then it stops right?
Old July 10th, 2011, 12:56 AM   #6
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
Sounds like exhaust leak from the manifold.
2004 Bolt on & Cammed 3.9L V6
Old July 10th, 2011, 05:57 AM   #7
adryan's Avatar
I just uploaded a video. Let me know what you guys think.
Old July 10th, 2011, 07:06 AM   #8
Lumoon's Avatar
2001 Mustang V6
Its a V6
Lumoon is an unknown quantity at this point
if its a sticky lifter I'd just run some A/T fluid in with your next oil change. I have an intermittent lifter on the front passenger side I've had it since I can remember and Its a common problem.
if you open the heads up and go to replace the springs or what ever else needs replaced I suggest getting a decent set of springs and valves.
Done so far:
3.73 w/ lsd rear end.
custom 91 octane tune by R Style Performance
rebuilt 4r70w
24% UDP pulleys
aluminum drive shaft
Windstar ready to be installed pending ported lower intake arrival
Old July 10th, 2011, 12:17 PM   #9
2000 v6 mustang
1slowv6 will become famous soon enough
HMM the video sorta helps.... it kinda doesnt sound like the manifold.
more like a valvetrain issue but rest assured it does not imo sound like a bearing.
i would take it to your engine guy and he should be able to tell you because something that high pitched and fast sounds like you may be able to pinpoint it by removing the valve covers
FYI i wouldnt be doing any WOT burnouts
If Nissan motorsports is Nismo..Wouldn't Honda motorsports be Homo?
Old July 10th, 2011, 02:15 PM   #10
Jetflo's Avatar
2001 3.8L w/ 5spd
Jetflo will become famous soon enough
As far as the internet diagnosis of your car's ticking noise:
1. Doesn't seem like a bearing. Bad bearings don't get quiet under load.
2. Could be a lifter. A bad lifter will work better when oil pressure is higher. This would fit with the observation that the ticking noise goes away under load.
Others have made this diagnosis before me. Here's are some recommendations to improve the situation.
1. Get a section of rubber tubing and use it as a stethoscope against the valve cover to pinpoint the valves that are making noise. This will confirm it is "valve tapping".
2. Try flushing the existing oil with SeaFoam then changing the oil and adding an oil treatment like Marvel Mystery oil or some ATF.
3. If that doesn't work, the lifters need to be inspected/replaced.
With a bit of luck, there is some gunk in one lifter that will come out without much hassle.
Good Luck!
Are you absolutely certain you're not pregnant?
Old July 13th, 2011, 11:03 AM   #11
ag11hockey's Avatar
1999 Mustang V6
sorry but mine sounds nothing like that. mine is mainly at an idle
Old July 13th, 2011, 07:41 PM   #12
adryan's Avatar
Originally Posted by Green_6er View Post
sticky lifter?
I've been to my machine shop/turbo guy and he said that it is a sticky lifter. I've been to my engine guy and he says the same thing but not want to discount other issues. My dad said it may be one bad valve lifter and he asked me if it was mechanical or hydraulic... I said I don't know. If mechanical, it may need to be adjusted and if hydraulic it needs to be replaced. In order to finalize the diagnostics, we all agreed to take it to the stealership. I'll find out from there exactly what is wrong before I let anyone rip the engine apart.
Options I'm seeing are from basic valve adjustment (if mechanical) to valve train replacement if hydraulic. Since it is on the driver side it seems, my machine shop/turbo guy said me and him could do it in a couple of hours (for free except the parts). My Nigerian engine guy needs to learn to speak english properly so I don't know if he really even knows what to do but he is cheap and he is my mom's workmate's husband. Next option is to let the stealership take care of it but I'm sure "kaching kaching" would be what I'll be hearing. Final option, since I am planning the winter turbo build with my machine shop/turbo guy and if the costs go beyond $5-600, is to drop in a 4.6 with complete harness, ECU and hopefully supercharged if I can find one for the right price. My turbo guy would be happy to do it since he's got a few supercharged vehicles that he drives, plays with and is actually putting together right now.
I have 74,500 miles and she's to young to be this sick. I'll see what happens after the stealership. Wish me luck guys.
Adryan
p.s. My dad asked me if I wanted to drop in the 427 engine from the Thunderbird that's just sitting in the garage and I said there's too much modifications and I personally would go for the 4.6 for a straight drop in. I'm not even sure if it would fit. And, I'm giving this car to my daughter when when she gets her license next year. I'm sure she'll have fun with it if I do...
Old July 13th, 2011, 07:57 PM   #13
mcqueen's Avatar
I believe we use hydraulic lifters.
My Hubpages
Old July 14th, 2011, 09:36 AM   #14
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Yes, they are hydraulic roller lifters. I'd try a little Seafoam or ATF before tearing into the engine. Either of those may free it up.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old July 14th, 2011, 08:52 PM   #15
adryan's Avatar
How much ATF should I use? I just had the oil change and I did drop in 3/4 liter of something from Canadian Tire... Risoline or something. No clue where to get Seafoam here in Canada.
A.
Old July 16th, 2011, 10:53 PM   #16
stephen has a spectacular aura aboutstephen has a spectacular aura about
A.
Risoline is supposed to increase the oil viscosity to give higher oil pressure.
It probably wouldn't help a sticking lifter.
Usually 1 qt of ATF with 4 qts of oil is recommended.
Old July 16th, 2011, 11:21 PM   #17
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Rich J is just really niceRich J is just really niceRich J is just really niceRich J is just really nice
Kind of sounds like a rod to me....
Formerly known as Demon_54
"I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Old July 16th, 2011, 11:26 PM   #18
mcqueen's Avatar
I was thinking that too. I've had a sticky lifter or two for a while and they never sounded like that.
Be careful driving that car too hard OP, last thing you want to do is throw a rod and end up needing a new block or something.
My Hubpages
Old July 16th, 2011, 11:31 PM   #19
I'm doing it wrong
Rich J's Avatar
04 Grand Cherokee
Sound anything like this OP?
Old July 17th, 2011, 12:01 AM   #20
spaseghost's Avatar
It makes my wife horny
16.3@84@5kft
spaseghost is on a distinguished road
ive got a really bad sticking lifter on the driver side. It goes away after about a minute of idling after initial startup. I use BG MOA or Restore and that seems to work for a week or so. Ill post a vid for you tomorrow.
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k
1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21
2004 Nissan Armada - HIDs, LEDs, sippy and DVDs
2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
Threads Similar to: Bad sound
What is this sound? normajean 99-04 9 March 11th, 2011 05:11 PM
Does this sound ok? Rich J Videos 3 August 30th, 2010 10:16 PM
surround sound/sound bar for ps3 and x box G.T. Rags The Clubhouse 38 July 6th, 2010 09:18 PM
looking for a new sound mjkids 99-04 3 September 28th, 2008 03:19 AM
Sound issue, (sound clip coming later) dgt_mustang V6 Mustangs 5 April 11th, 2008 05:08 PM
