head light cleaner?
Old July 10th, 2011, 03:54 PM   #1
6ixer's Avatar
2000 mustang v6
14.6@99.68
6ixer is on a distinguished road
head light cleaner?
so i remember seeing/hearing on here that you can taike.....toothpaste?? and apply it to a foged or condensated head light and buff the S*** out of it and it removes the fog or cloudy ness in the head light.....i shtat correct?\
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust
Fixed clutch!!!!!
"My mustang likes a good ol' fashion bowl of rice....especially fried"
Old July 10th, 2011, 04:17 PM   #2
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! is a jewel in the roughmustangmike! is a jewel in the roughmustangmike! is a jewel in the rough
it can yes. maybe not 100% but it should help.
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old July 10th, 2011, 04:25 PM   #3
v6 stunna's Avatar
2000 v6
v6 stunna is on a distinguished road
throw some on there and go to town nigga and see what happens..only good can come out of it
Old July 10th, 2011, 04:34 PM   #4
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
wet the headlight with soapy water, then put some toothpaste on it adn use a rag to buff it a little applying some pressure.
Basically you know how toothpaste is kinda crunchy like. almost like it has very fine sand in it. Well thats the idea behind it, its basically like wet sanding the light with a very very fine sandpaper.
2004 Bolt on & Cammed 3.9L V6
Old July 10th, 2011, 04:38 PM   #5
walt1120's Avatar
14.45 @95.8
6ixer, you always have the worst typed out posts lol.
Old July 10th, 2011, 06:12 PM   #6
if toothpaste isn't gritty enough for your headlights...there's a new kit at Advance i just used that is amazing...it's like a standard sanding kit, but it has a clear coat that you finish it with that has a 6 hour cure time before reinstall...i no longer need to buy new headlights lol and all for $20
btw...the kit is by sylvania...its in a yellow box
Old July 10th, 2011, 06:15 PM   #7
Stang808's Avatar
2004 Mustang v6 3.9
Stang808 is on a distinguished road
also their is a kit by 3M has..as for toothpaste not sure but let us know how it goes
Old July 10th, 2011, 06:20 PM   #8
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
i have both products by headlamp lens restorer, the chemical that gets them clear and then the sealant to apply after. you just use a terry cloth rag with mild pressure in circles and its the best stuff, plus you have alot left over so you can keep it and use it again when the weather has taken its toll again, or do you friends and family and they'll be like "Damn!!"
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old July 10th, 2011, 06:22 PM   #9
i don't like those kits lol...i like a good sanding kit that solves the problem of hazing and not just covering it up for a timespan...
Old July 10th, 2011, 07:35 PM   #10
BlueScreaM's Avatar
Better than ONLYaUNCfan's
2012@lightspeed
BlueScreaM has a spectacular aura aboutBlueScreaM has a spectacular aura about
3m > everything else.
Formerly, AhobosCheese and Cheddars.
Old July 10th, 2011, 07:38 PM   #11
i've used a 3m kit on my GT...got to say i like the new sylvania kit more...the sanding is easier with the 3m kit due to the drill adapter...but the clear/sealent is better with the sylvania kit...i wonder...time to mix the kits up lol
Old July 10th, 2011, 08:31 PM   #12
6ixer's Avatar
2000 mustang v6
14.6@99.68
Yeah ik I'm on my phone typing this and here's a lagg on what I'm typing and what actualy is being typed....like when I'm typing I'm about 5 words ahead of what's actually on my keybord
Fixed clutch!!!!!
Old July 10th, 2011, 09:01 PM   #13
Jetflo's Avatar
2001 3.8L w/ 5spd
Jetflo will become famous soon enough
There's a headlight restorer kit by Meguiar's called "Powerball".
It worked better than the cure time liquid gel headlight stuff. However, if you are really fussy and the headlights are yellow now, you are going to be sanding and polishing for a while.
I've also found that here in the California sun, the headlights start to fade again in about 6 months. You can probably live with every other year, but you should be warned that none of these treatments are magic.
You should still be really impressed with how much better your headlights will look with even the smallest improvement.
Good luck!
Are you absolutely certain you're not pregnant?
Old July 10th, 2011, 10:58 PM   #14
kingcudi's Avatar
2000 Mustang V6 3.8L
kingcudi is on a distinguished road
Mine were straight yellow when I got the car, used I think the 3M kit with the 4 different grit sandpapers and the drill adapter, also I found that this stuff called Plast-x worked ok for the really tough yellow. Used that stuff first then used the 3M kit, my headlights are clear now!
Old July 10th, 2011, 11:39 PM   #15
Jetflo's Avatar
2001 3.8L w/ 5spd
I forgot one thing: take the headlights out before using the drill attachments on them
You don't want to mess up your paint.
Old July 11th, 2011, 08:59 AM   #16
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Yes, toothpaste will work. Compare the ingredients to buffing compound and toothpaste. The major ingredients are gel, water, and silica (sand). Your toothpaste is just minty buffing compound with flouride.
Keep in mind it isn't as effective as buffing compound. You really don't need one of those kits, and you sure as hell don't need the infomercial stuff. For the most effective treatment, hit it with 1000-2000 grit sandpaper with some warm soapy water, then polish with a good buffing compound, and if you're really after a nice finish, a clearcloat.
You don't need to remove the headlights, just tape off the paint. That's a daily procedure for the professionals.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old July 11th, 2011, 11:24 AM   #17
BlueScreaM's Avatar
2012@lightspeed
Blue magic (black magic) sell a bottle of headlight sealant. I haven't used it yet though.
Old July 11th, 2011, 01:37 PM   #18
6ixer's Avatar
2000 mustang v6
14.6@99.68
Blue are those smooked head lights or darked out head lights in ur sig.....?? J/w for a futre reference for my car
Fixed clutch!!!!!
Old July 11th, 2011, 06:45 PM   #19
spaseghost's Avatar
It makes my wife horny
16.3@84@5kft
spaseghost is on a distinguished road
i wet sand with 600, 1000, then 2000, polish them up, and then wax. works great, just takes a while.
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k
1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21
2004 Nissan Armada - HIDs, LEDs, sippy and DVDs
2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
Old July 11th, 2011, 07:04 PM   #20
MM's king of Neon's
404 - car not found
17.81@87
Wow, those must be some pretty oxidized headlights if you went down to 600 grit. Most of the time 1000 grit or just some buffing compound will do it.
Threads Similar to: head light cleaner?
The Ultimate Wheel Cleaner - Sonax Full Effect Wheel Cleaner DetailersDomain General Car Care & Detailing 10 February 25th, 2011 12:53 PM
Head light removal itschristorres8 2005 - 2010 12 November 24th, 2009 05:36 AM
head light question disturbdgt 99-04 32 April 30th, 2009 10:52 PM
head light covers mannymustang The Clubhouse 2 April 26th, 2008 03:31 AM
Head Light and Tail Light Opinion Needed Laser Visual 8 January 2nd, 2008 02:16 AM
