What size are the exhaust manifold bolts?
Old July 13th, 2011, 02:36 PM   #1
Codeman's Avatar
Codeman will become famous soon enoughCodeman will become famous soon enough
I got some LTs I am going to be installing bought them used. Well Ford wants $7 a piece for the studs. I am curious to what size and pitch? I am guessing like an m8 1.25? Anyone know for sure? I work for a chevy dealer and can get parts at cost and if I know the size I can have them just order normal exhaust bolts that will work except for less money.
UDP, CAI, True Duals, LTs, 91 Tune from TT, 3.73 gears, Tlok,Windstar upper, GT TB, Ported lower, Comp 218/226 cam, FRPP C Springs, J&M LCA, Tokico Blue shocks and struts, and J&M Full Length Subframe Connectors
Old July 13th, 2011, 02:59 PM   #2
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
m8x1.25 seems correct but its been a while...... And yes get the bolts don't mess with those studs.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old July 13th, 2011, 03:05 PM   #3
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
The guy who assembled my heads said that some of the studs got stuck in the old heads (he damaged the threads removing them) so he just used regular hex screw and bolt instead of studs.
We used 8mmx1.25x40mm bolts.
Of course id recommend using studs but at the time i didnt care.
2004 Bolt on & Cammed 3.9L V6
Old July 13th, 2011, 04:27 PM   #4
Codeman's Avatar
Ok thanks. I am planning on using bolts. IDK why ford put the studs on unless one of their other vehicles that used the 3.8 had a heat sheild on the manifolds. Kind of dumb in my eyes.
Thanks for the help.
Can't wait to get the LTs on I next need some cutouts so I might have to order some before I put them on so I can do it all at once. Not electric though too expensive maybe down the road though.
Threads Similar to: What size are the exhaust manifold bolts?
Exhaust manifold nut size??? Lift-O 99-04 4 June 27th, 2011 05:50 PM
passenger side exhaust manifold nut size? thehrtbrkkid 96-98 6 November 27th, 2010 04:41 PM
Exhaust manifold bolts stuck BlackPony99 General Tech 2 May 12th, 2010 04:58 PM
Help me identify these two holes / bolts on intake manifold. Gregski Mustang II 6 March 20th, 2010 12:13 PM
what size bolts jersey98gt 96-98 9 May 14th, 2007 11:10 PM
