16.Something@Low80s
Trying to remember nec. changes to install gears... Tune/Speedo/Etc.
Been away for a bit. Bought a set of gears and Tlok, but the installation was always slated for "later when I can afford the $ and time..." Timing is better now and I need to re-run through the changes needed to support the gear switch.
I know I need a specific Speedo gear (I've got a 98 auto, going to 3.73), I've just heard conflicting answers on which to use for a 98 auto going 3.73s, I've heard just about every number between 18 and 23... I know where this is and how to get to it, just wanna know if any other 98er has a dead-on speedo with what gear. I pulled mine today and it's an 18, so I'm guessing 21-23? And I assume I'll need a re-tune for the shift points, correct? As far as I know, the speedo gear will correct my speed, but I think I need the retune to get the shift points adjusted. Correct me if I'm wrong. Aside from the install/bearing kit/oil change...Is that it? And/or am I wrong on either of those assumptions? Thanks to those who have helped me before, just asking you to bear with me one more time... |
Threads Similar to: Trying to remember nec. changes to install gears... Tune/Speedo/Etc.
| Will SCT3 tune fix speedo after gears | justin503 | 2005 - 2010 | 14 | March 17th, 2011 07:27 AM |
| Speedo after gears. Where to buy gears and speedo fix... | justinsstang | V6 Mustangs | 9 | September 15th, 2010 02:57 PM |
| speedo gears | MikeD05GT | 96-98 | 8 | September 15th, 2009 06:25 PM |
| Install labor hours for CAI/Tune, and 4.10 gears | 05GTinNC | 2005 - 2010 | 22 | February 6th, 2009 08:46 PM |
| speedo gears | FoxHoss | 5.0 Mustangs | 7 | September 11th, 2008 12:22 PM |
